Wts light while driving
Old Feb 14, 2014 | 03:46 PM
bobracing32's Avatar
Default Wts light while driving
My 06 with throw the light while driving. Now before the first guy says use the search button i have. My problem is only the wts light. Not with a 1222/1223 only the wts light. Loose power when it comes on let off throttle for a while it shuts off. Only does it when pulling for some reason. Now since its not grouped with a fuel code what other issues could it be? Also the tipm is new with latest flash.
Old Feb 14, 2014 | 09:31 PM
cerberus60's Avatar
The WTS and derate the result of the leak detection that sets 1222 and 1223 codes. The leak detection happened mutiple times in a couter time period and the engine derates when that happens. If you light foot it around for a while the CEL will likely go out but the next time you push it the CEL and derate will be back.
You have those codes stored in the ECU and need a code reader that can retrieve them. The 06 CAN systems are a bit different for code retrieval so they don't work like the earlier trucks.
You either have some injectors pooched, PRV leaking, or FCA messed up. Usually its injectors.
Old Feb 15, 2014 | 08:58 AM
mysterync's Avatar
Couldn't have said it better myself.
Basically a solution dodge found to prevent catastrophic engine failures caused by injector failure.
Sent from my SCH-I605 using Tapatalk 2
Old Feb 17, 2014 | 09:39 AM
Like I said the associated fuel codes 1223/1222 do not come up with the light. So is there any other problems known with the wts light other than the fuel issue. The truck will kick on high idle at 200 degrees could a sensor be bad?
Old Feb 17, 2014 | 10:55 AM
mysterync's Avatar
What are you using to check codes?
Old Feb 17, 2014 | 03:12 PM
Modis
Old Feb 17, 2014 | 03:43 PM
mysterync's Avatar
That I know of those are the only know causes of your issue. I imagine you could have a ignition switch issue but it would likely cause more severe or obvious sypmtoms. And you've looked at pending, current and history codes?
Do all sensor pids rational and react normally?
Old Feb 17, 2014 | 08:44 PM
cerberus60's Avatar
It is highly likely the codes are there your Modis is just not able to understand them.
Very well estasblished the WTS light and\or chimes and\or derate is the leak detection DTC. Whether or not you can find the codes doesn't mean as much as the fact you are seeing the results.
If you suspect other problems then you are going to need to get some gauges on it and see what is happening with the boost, EGT's, rail, pressure, etc.
If you are doing that then you need to run the injector tests also to find the problems.
Old Feb 17, 2014 | 08:53 PM
mysterync's Avatar
Agreed. I'd be interested to know what version is on the modis!
As mentioned very good time to do a return volume test.
1ATony
1A Auto Parts
Jul 30, 2015 12:44 PM
MERMAR
11
Apr 26, 2015 07:01 PM
carid
Diesel Bombers Sponsors
Apr 15, 2015 07:29 AM
Baconjosh
8
Dec 11, 2014 03:16 PM
Muscle1967
Nov 14, 2014 06:49 PM
