Replacing Stanadyne Model 80 with a screw on type filter.
Old Feb 13, 2014 | 06:39 PM
wowzers's Avatar
Default Replacing Stanadyne Model 80 with a screw on type filter.
I noticed my filter was leaking, so I pulled it off to find out that the bottom right pin/ plug (if you were looking at the firewall) is broken off. I went to go check my old filter and sure enough it is in the old one. So there is a small chance I might have found a replacement base, but if that turns up dry, can I get away with just deleting the Model 80 and going to a normal screw on type. Is not having a heater on the filter going to be an issue?
Old Mar 24, 2014 | 03:09 PM
lessersivad's Avatar
I realize this isn't exactly a new thread but I'll reply anyway.
What you are wanting to do is exactly what I did one my '85.
IIRC I bought mine off ebay, may have been amazon. The base also has a built in primer/plunger and bleeder on the top so you can prime the system after a filter change.
I've had no problems with the deletion of the stock filter. Even in the sometimes sub 0° winter we just went thru.
Hope this helps.
Bob V
Apr 6, 2015 11:02 PM
