changing the gearing???
Old Feb 12, 2014 | 08:55 PM
Rayrod's Avatar
Default changing the gearing???
I am thinking of changing the ring and pinion gears in my truck to gain a little more top speed. any suggestions?? I don't know much about it. what is the stock ratio? want to put a locker in the rear end as well. any helpful information on the subject would be great.
thanks guys!
ray
Old Feb 13, 2014 | 08:37 AM
RAW's Avatar
RAW
What you gain on the top is what you will loose on the bottom. There is always a trade. You should be able to find your ratio on a sticker in the glove box.
Old Feb 13, 2014 | 08:12 PM
Rayrod's Avatar
about how much would I lose on the bottom end?? if I changed from stock. just a geustimate?? im not to worried if its going to be just a little bit. but if its a substantial difference I wont bother. like I said I want a bit more top speed. not like im a heavy speeder. but yes I would like my truck to be able to go faster then 120kmph comfortably. and yes I realize its a diesel and there not high revving engines. but just asking for a bit more top speed shouldn't be a problem.
thank raw
Old Feb 15, 2014 | 04:49 PM
Greenbeast's Avatar
My truck has 4.10 gears and needs another gear on the highway. the 4 spd auto does not cut it for the highway.
Old Feb 16, 2014 | 01:03 AM
BarryB's Avatar
My truck, has 3:55. on the Hwy. it does great. 70mph no problem rpm around the 1800 area I believe.. BUT the trade off, is in town. it sucks, constantly changing gears.
Old Feb 16, 2014 | 01:16 PM
Rayrod's Avatar
im ok with changing gears lots. any difference in power on the bottom end? was it really noticeable or not? what brand do you have?
Old Feb 16, 2014 | 04:23 PM
12vcumminspower7's Avatar
Agreed
Old Feb 16, 2014 | 05:50 PM
RAW's Avatar
RAW
The Auto has a higher top gear ratio than the 5 and 6 speed, FYI. Having a 5 or 6 speed would make the situation worse, if that is what your thoughts may be leading to.
Old Feb 18, 2014 | 11:47 AM
tbirdz24v's Avatar
You have the same setup as me. All the 6 speeds have a 3:55 gear ratio. Driving my dads with a 4:10 ratio sucks!!!! Plus not only is changing gears going to change a power issue. Its also going to change fuel mileage also.
Old Feb 18, 2014 | 08:09 PM
Rayrod's Avatar
so my truck being a 6 speed has 3:55 gearing? soo I want to be even a tiny bit faster then that. not a lot. just a bit. what is the next size down? or up? how ever it works.
