06 dodge cummins 5.9 VERY loud knock
Old Feb 11, 2014 | 09:34 PM
newdieselguy9's Avatar
Default 06 dodge cummins 5.9 VERY loud knock
Ok my truck lost power had a huge cloud of white smoke. I tried to drive it home and died wouldn't start again. I changed the injectors with bosh 505's checked the lash on the valves and now it has a very loud knock that my girlfriend heard it in the house. I sounds like a piston hitting the head, but it didn't do that before I changed the injectors. I don't want to pull the head unless it is absolutely necessary. Any suggestions would be helpful!!!!
Old Feb 12, 2014 | 03:44 AM
mysterync's Avatar
Sounds like a faulty new injector. Think I'd kill an injector at a time until the knock left and send that one back!
Sent from my SCH-I605 using Tapatalk 2
Old Mar 1, 2014 | 01:59 PM
Default Still not working
Ok I did an injector kill test and I heard the difference on all cylinders except #4 So I changed the number 4 injector wit the #1 injector and did the kill test again wit the same results. I checked the voltage on the injectors and it is the same on all 6 I have new injectors and feed tubes, I checked lash, compression is between 250 and 260 on all cylinders the contribution test was all cylinders were above 100% except the #2 was at 80. Fuel pressure is 10 psi from the pump and the rail pressure at idle is between 5500 and 6000 at wot it is around 18,000. When I start the truck cold the engine sounds fine no ticking or knocking a small amount of white smoke. When I rev the engine excessive white smoke. When the engine warms up I the smoke gets a blue tint to it but not as excessive and I get a lot of blow by any suggestions would be much appreciated.
Old Mar 1, 2014 | 03:01 PM
mysterync's Avatar
Did the knock ever stop? Sounds like an internal issue on number four considering the miss didn't move with injector. Compression is low across the board. Might try a wet compression test. Likely a fuel wash situation caused ring wear. Next step would be pulling the head and making a decision on the route of repair. It's worth verifying the lash adjustment and proper injector seating. If compression gasses leak around a copper washer some of the same symptoms will occur, be more likely in one cylinder.
Old Mar 1, 2014 | 08:03 PM
wen the truck is cold there is no knock, but when it warms up it is there constantly it sounds like a lifter ping but it is more pronounced on the passenger side
Old Mar 1, 2014 | 08:34 PM
mysterync's Avatar
What type of oil pressure with a manual gauge? Regardless I think we can say we've got internal issues.
Old Mar 2, 2014 | 01:57 AM
I haven't hooked up a manual gauge and I don't recall what the dash gauge is saying. I just remember looking at it and thinking it was normal. I have Auto Enginuity there is a lot about it I don't know and am just learning about. Under the enhanced power train there are no codes but the generic power train there is a bunch of useless stuff, there was one code about the map sensor. I have been thinking it was internal, but was really hoping that there was something else going on that I was not looking at. I really appreciate your help I can do lots with cars and trucks as far as suspension and replacing things but diagnosing and engines I am still learning. Learning is a never ending battle
Old Mar 2, 2014 | 07:58 AM
mysterync's Avatar
Your 100-150psi below compression test on engines of the same year so that's one issue that needs to be addressed. Without hearing the "knock" it's hard to say if it's a fuel knock or internals. My first guess would be injector causing the knock.
Old Mar 13, 2014 | 05:43 PM
private792's Avatar
I have a 2006 5.9l megacab with the same issue, changed all 6 injectors, did a kill test and #4 need to be changed again, so changed injector, and no change, very frustrating, its been like this for 11 months.
Old Mar 14, 2014 | 09:29 AM
I ended up pulling all the injectors back out and ran another compression test. The all of them came up at 350, which was a big improvement from the first test. Unfortunately the #5 was at 90 so I added some oil and it cam back up to 250 so I pulled the intake rockers off and did a leak down test and now there is air coming out the intake side. So now I have to pull the head. I would do the same if I where you just to be on the safe side.
