Chevy/GMC Duramax 04.5-05 LLY Discussion of Chevy and GMC Trucks with LLY Duramax Turbo Diesel Engines
04.5 duramax problems please help
Old Feb 11, 2014 | 01:56 PM
zx6r0636r's Avatar
Default 04.5 duramax problems please help
I started working for a fleet that has mostly duramaxes. They are new to me i was mostly a john deer mechanic. Here is the issue ontle of our trucks an 04 3500 cab n chassis started blowing constant black smoke and would not start without assistance they took it to the dealer and found out what it needed
The dealer said to replace all fuel lines sending units, #2#7 injectors and the cp3. Thats where i came in they hired me i said sure ill try. I got everything in truck fired right up. Truck only had 52790 miles on it within 12 miles of testdriving it the same exact symptoms aroused. Anyone have ideas on possible problems? Balance rates where all within specs right after all parts installed. Now they all look to be skyrocketed. Some are upwords or 8.6 at idle when they where all around 1.4 and-1.5 12 miles ago
Old Feb 15, 2014 | 12:44 AM
2004LB7's Avatar
look up the ice pick trick.
the connectors to the injectors get loose and that creates a bad connection and throws everything else out. this may be the issue. quite common with the LLY #2 & 7 injectors. there is also supposed to be a TSB out on this and a repair kit for a more permanent fix.
jt19
Aug 20, 2015 12:18 AM
Jul 28, 2015 12:40 PM
jt19
Jul 13, 2015 03:06 PM
duramaxtuner
Dec 10, 2014 01:24 PM
tbreddiesel
Thoroughbred Diesel
Oct 29, 2014 02:40 PM
