Power Steering Pump
Old Feb 9, 2014 | 10:26 AM
DodgeJohn2013's Avatar
Default Power Steering Pump
I have a 2001 2500 cummins and I noticed that it started leaking power steering fluid from the top of the reservoir. Also when I start it when its cold outside it whines really bad especially when you steer or step on the breaks. Help Please!
Old Feb 9, 2014 | 09:17 PM
six speed's Avatar
it sounds like you have air in it.
keep it full of fluid and drive it a few days and see if it gets better. mine did this for about 3-4 days after i changed the old pump out.
Old Feb 10, 2014 | 08:18 PM
brand97's Avatar
Mine does the same but I haven't done anything new with the pump???
Old Feb 10, 2014 | 09:49 PM
six speed's Avatar
when i bought my 97 it had been sitting for a couple months. the power steering and brakes were doing this. the fluid in the pump looked like thin mud, so i determined the pump was probably bad. changed it out,and flushed the system, and still had the same problems. Jacked it up,turned the tires back and forth while the engine was off to work the air out. this helped somewhat but i wound up driving the truck for about 3 days before it finally got all the air worked out, the hydroboost quit whining and it got easier to steer.
Old Feb 13, 2014 | 10:01 PM
lilmike1540's Avatar
guys just so you no my 01 did the same thing and it turned out to be a bad cap got a new one and works great and as long as its a saginaw cap it will fit just swap over the cavitation ring and you have it
b&hbiz
Sep 9, 2015 07:53 AM
Antwhite19
Aug 23, 2015 06:07 AM
ramrunner01
Jun 1, 2015 12:10 AM
moneypitk5
Feb 12, 2015 11:01 AM
sweetv8s10
Oct 7, 2014 09:47 PM
