lack of power, running out of ideas.
Old Feb 8, 2014 | 11:52 PM
Icanrydit's Avatar
Default lack of power, running out of ideas.
I recently purchased a 2000 dodge cummins. Auto tranny, truck idles and started fine, but no power. Topped out at 40mph. It tgrew 234, 236 codes. I have added a fuel pressure light, replaced the turbo as the old waste gate was seized, i cleaned the map sensor, and installed a fass fuel pump. Truck runs with a little more power, but still takes a good mile to reach 55mph. Fuel pressure light is now on once i get into it. No smoke, no codes, have great fuel pressure to fuel filter. I am not sure what do next. I thought I'd the fuel pump is damaged the truck won't run. Anyone there able to give me some advice?
Old Feb 9, 2014 | 08:24 AM
mysterync's Avatar
What type of boost numbers is it producing?
Sent from my SCH-I605 using Tapatalk 2
Old Feb 9, 2014 | 08:59 AM
Icanrydit's Avatar
To be honest i do not know, i dont have a boost tester. Any home made setups or suggestions? I do have the torque app scan tool on my phone maybe that will show ill go check
Old Feb 9, 2014 | 09:27 AM
mysterync's Avatar
The torque app will do it I think. Just select live data, then look for the map sensor pid. Write down the base number (barometric pressure), drive the truck and watch for the highest number then subtract the base number. Depending on the measurements torque uses for map you'll likely have to convert it to psi.
Old Feb 10, 2014 | 07:06 PM
Icanrydit's Avatar
Mysterync, i appreciate your help. Here is my update: i download the full torque app, checked boots and cleaned the map sensor and went for a drive. For the first time i felt Loads of power, it was a rocket all of a sudden. Then 1/2 mile later as i pulled back into three farm it went back to gutless. So i am pleased that it us possible to have power, i have hope. However I registered no boost whatsoever. And i got the 236 code again, so i am guessing i need replace the map sensor. Do you think i am not reading any boost due to a bad map? Or could i have another issue? And i am guessing i didn't have codes after installing the new turbo because i didn't drive it far enough? I feel i am close
QUOTE=mysterync;1048246]The torque app will do it I think. Just select live data, then look for the map sensor pid. Write down the base number (barometric pressure), drive the truck and watch for the highest number then subtract the base number. Depending on the measurements torque uses for map you'll likely have to convert it to psi.
Sent from my SCH-I605 using Tapatalk 2[/QUOTE]
Old Feb 10, 2014 | 08:09 PM
mysterync's Avatar
Sounds a lot like a map sensor failure but let's start by back probing the sensor with the wire plugged in and our meter ground lead on the negative battery post. Check each pin with the key on, when you find one that reads 0v switch your negative lead to b+ and verify that reads 12v. We'll go from there on the diagnosis.
Dieselhead6.5
Oct 6, 2015 09:47 AM
Ryans71
Diesel Engine Conversions
May 31, 2015 01:57 PM
