2001 good batteries, lights work, no power
Old Feb 7, 2014 | 09:32 PM
hrdhatdvr's Avatar
Default 2001 good batteries, lights work, no power
I have 2 good batteries, good connection on terminals. Interior light works, headlights work. No power to anything else no dash no fuel nothing. Oh the door locks work and the door buzzer. Any ideas?
Old Feb 9, 2014 | 12:07 AM
jrconsultid's Avatar
Default Tech Service Bulletin (TSB)
I saw your post and I was curious if you have seen any codes showing up? Below is TSB that may be of some help.
Dodge Cummins
TSB#
08-26-00
MODEL/Year
‘00 - ’01
SUBJECT/DESCRIPTION
Central timer module electrically “locks-up.”
This bulletin applies to vehicles equipped with remote keyless entry (sales code GXR). In addition, this bulletin applies to vehicles built on or before the following build dates: Ram trucks built at the St. Louis North Assembly Plant on or before August 21, 2000; Ram trucks built at the Saltillo Truck Assembly Plant on or before August 31, 2000; Ram trucks built at the Lago Alberto Truck Assembly Plant on or before September 6, 2000. The repair involves replacing the Central Timer Module (CTM) with a revised part.
Date issued: 09/29/00
Old Feb 9, 2014 | 08:19 AM
mysterync's Avatar
Re-read it's not pdc related. Have you checked all the fuses?
Sent from my SCH-I605 using Tapatalk 2
Old May 4, 2014 | 01:39 PM
rhitch's Avatar
check for fuses................next to flasher, same amp as flasher had same problem hope this helps
Rcracer78
Audio Equipment/Electrical
Apr 20, 2015 12:49 AM
carid
Diesel Bombers Sponsors
Apr 15, 2015 07:29 AM
willgoss
Ford Powerstroke 08-10 6.4L
Feb 12, 2015 09:52 PM
bypass-21
Jan 3, 2015 04:47 PM
