low end oil pressure question
Old Feb 6, 2014 | 04:23 PM
DrivenMad's Avatar
Default low end oil pressure question
2004 f250
6 liter turbo
new batteries
I recently replaced the hpop, did air test after with no leaks. all my high pressure seals are done and dummy plugs. The truck ran for about 1 hour then died on the side of the road. So i backed up and started with the basics and found that im getting no low end oil pressure. i piped in a mechanical gauge on the top of the oil cooler cover where the oil pres. switch is. I am getting no reading at all on the gauge cranking. The next step I took the oil filter out and used a long flat head screwdriver to close the valve that lets the oil back into the crankcase when doing filter change. the oil oozes out of the front hole while cranking and very slowly starts filling the housing. it fills about 1/8 of the hosing after cranking for 10 seconds. My thought is that the pump/ cover is shot. Should the oil be filling the housing faster?
Thanks
Old Feb 6, 2014 | 07:11 PM
Adrenaline junkie's Avatar
I would say low pressure pump done if not filling housing and no or very low pressure at port. How many miles on truck? The low pressure feeds the high pressure system.
Old Feb 6, 2014 | 08:38 PM
DrivenMad's Avatar
Default miles
225k on engine. fantastic maint. record , and one owner Thats how i finally came to the low oil pump, was using a scangauge 2 and still was getting 0 pressure on hpop , even after replacement, SO I was saying, " Alan, go back to the basics, your missing something! "
by chance do you know of a resource for a front cover R and R procedure?? Will be tearing apart the front my self, I would feel better having a good reference
Thanks again
Old Feb 6, 2014 | 08:51 PM
bobfbigman's Avatar
Normally it is just the pump itself,gears, and not the whole cover. pull the pump first and inspect the cover, if cover is good then you will save 700 bucks. the pump is located right behind the balancer, so removal of the fan and shroud then the balancer the pump cover will be right there and easy to get to.
Old Feb 7, 2014 | 12:00 AM
DrivenMad's Avatar
Default :) perfect :)
very cool ! very good to know ! Thank you. can i test clearances with just pulling the pump? Trying to figure out how to tell if the gears are bad or not.
Thanks !!
Old Feb 7, 2014 | 01:37 AM
DrivenMad's Avatar
Default oil pump 2004 6 liter specs test
Just found this searching around hope it helps someone else
File Type: pdf
Old Feb 7, 2014 | 03:16 PM
bobfbigman's Avatar
Normally you won't need the feeler gauges, just pull the gears and look at them, bad ones will be nicked up and have dents in them from something. if you have cylindrical marks about half inch long and about 1/16 wide then it may be more drastic. that is about the size of the needle bearings out of a lifter.
robbyS
Apr 16, 2015 02:22 PM
jhprice
Mar 29, 2015 09:36 PM
Ruddedawg5.9
Mar 1, 2015 09:16 PM
powerstroke4178
Nov 27, 2014 02:35 PM
Jeremy Babb
Chevy/GMC Duramax 01-04 LB7
13
Oct 1, 2014 06:27 AM
