Rear end rebuild
Old Feb 5, 2014 | 08:33 AM
brand97's Avatar
Default Rear end rebuild
So I am going to pull the rear end out of my 99 as the bearings are shot and just curious as I am putting it back together basically stock.. don't do much with it as its a driver?? anything else to look into??
Old Feb 5, 2014 | 08:52 AM
yjay's Avatar
It's quite a chore. Pulling the bearings off the carrier can be a pain as can putting the new ones on. You need a press and probably a bearing splitter. To do it right you also need a magnetic base dial caliper to check backlash, and a set of dial calipers would be helpful to measure shim thickness behind the side and pinion bearings, and to measure the difference in race thickness between the old and new bearings to give you a starting point.
I've done it before and will take it in if it needs done again. I was re gearing which is a little more complicated, but doing gears in general sucks in my opinion.
If you don't get the backlash, tooth pattern, and side bearing preload correct, it won't live long.
P.S. If your truck has a limited slip, it would be the perfect time to put new clutches in it.
Old Feb 6, 2014 | 03:16 PM
brand97's Avatar
I having it and thank y done them a few times in chevys, never a dodge,... will see I hope im not regretting it... thank you
shingi
Off Roading
Sep 30, 2015 11:17 AM
Machinist
Jun 23, 2015 06:57 AM
sjslhill
Apr 27, 2015 03:58 PM
2FordStrokers
Jan 11, 2015 09:40 PM
perk7089
Oct 11, 2014 05:03 PM
