My 99 Cummins will not start :(
Old Feb 4, 2014 | 02:01 PM
Jeff Fitz's Avatar
Default My 99 Cummins will not start :(
Okay so Saturday I drove my truck about an hour pulling my buddies truck to sale it, we went back to his house and when I went outside to leave, my truck was barely cranking over.. I thought my batteries were shot so I had him jump me. It took forever but finally started, it didn't seem like the jump helped I just got lucky. So Monday I go to work its starting perfect like usual and after work I go home shut my truck off and it hasn't started since then. It would turn over real slow, not enough to even start the truck. Now it won't turn over at all, I'm stuck on what to do. I had my batteries tested my alternator and starter they all are good. I thought loose connections so I replaced my battery terminals and cleaned the battery posts and still nothing. Any help would be greatly appreciated, thanks. Also there are not codes shown, the check engine light is off.
Old Feb 4, 2014 | 05:24 PM
mysterync's Avatar
Voltage drop from b+ to starter b + , sounds like a bad starter. How did you test it?
Sent from my SCH-I605 using Tapatalk 2
Old Feb 5, 2014 | 09:12 AM
Jeff Fitz's Avatar
It is my starter I took it to o reillys and had it tested they said its good well we took it apart and its garbage so I'll be replacing my starter
Rusher48
Jul 2, 2020 08:39 AM
mcclusk
Feb 21, 2015 09:50 PM
Rusher48
Feb 20, 2015 05:19 PM
rschriek
Jan 26, 2015 07:30 AM
Downd19
Dec 30, 2014 02:49 PM
