stage 1 injector supporting mod
Old Feb 4, 2014 | 10:00 AM
Bigredpowerstroke's Avatar
Default stage 1 injector supporting mod
Can someone help me with a list with all the supporting mods I will need for stage 1 injectors on a 97 f350 7.3 including tranny, hpop, turbo and everything else. I already have exhaust gauges and chip.
Old Feb 4, 2014 | 01:39 PM
joebob3093's Avatar
Moderator
You can get by with nothing if you want. Depending on what you want to spend E-fuel is nice, T500, and tranny stuff depending on what you have
Old Feb 4, 2014 | 01:48 PM
What do you suggest I do to make sure nothing goes wrong? And make sure everything holds up? And it is an auto so do I need to upgrade my tranny or what?
Old Feb 4, 2014 | 02:35 PM
joebob3093's Avatar
Moderator
Everything will work, it all depends on what kind of shape there in. The stock fuel should be able to keep up if it's in good shape. The hpop is the same way, if its strong it should be ok. Your tranny should be ok for a little while depending on what you do with it and how you drive.
But if you want to spend the money it should help. An electric fuel system from irate will be a lot better then stock. A T500 will be more then enough for stage 1s. As for the tranny you might get by for a while with a shift kit.
Old Feb 4, 2014 | 03:24 PM
How do I know if either fuel or hpop is in bad shape? And I'm mostly gana keep it in an economy tune buy once In a while I'll get on it?
Old Feb 4, 2014 | 04:04 PM
joebob3093's Avatar
Moderator
Need to get a fuel gauge and scanner that will read icp or an hpop gauge
coal_life
Aug 26, 2015 07:50 PM
truckerchuck76
Aug 14, 2015 10:46 AM
Diesel Addict
Price Quote - Request A Price
Jul 23, 2015 02:28 AM
DPRacing805
For Sale
Nov 15, 2014 12:47 AM
Zakkb787
LB7 Performance
Sep 27, 2014 08:47 PM
