Looking at getting a 1 St gen. problem tho
Old Feb 3, 2014 | 03:01 PM
birdman01's Avatar
Default Looking at getting a 1 St gen. problem tho
I'm lookin at pickin up a 89 d250. For only 2500 bucks it's a good deal but the front suspension is shot. The seller says it just wobbles at certain speeds, he uses it as a daily driver tho so it can't be too bad. What would anyone recommend to so about fixin it? Could I just pull the front suspension off another 89 or would it be better in the long run to just put after market on it ? Also any pointers to look for when buying a 1st gen
Old Feb 3, 2014 | 03:06 PM
12vcumminspower7's Avatar
Auto or Manual?Is the suspension the only "major" thing wrong?
Old Feb 3, 2014 | 03:19 PM
birdman01's Avatar
Ya seems to be. It has a new injection pump and a vacuum pump well doesn't have ac or heat but that isn't a concern to me.
Old Feb 4, 2014 | 11:04 AM
cougar's Avatar
Just rebuild the front end. Unless the A frames are worn through it's just bushings and ball joints. A whole lot easier job than doing king pins on a 4X4.
Old Feb 4, 2014 | 05:38 PM
u2slow's Avatar
+1
Check the steering links and idler arm for play. All cheap stuff to replace.
Old Feb 4, 2014 | 08:21 PM
birdman01's Avatar
I have 0 experience with trucks mechanic
al wise. IV worked on bobcat front loaders and mini track hoes but never trucks. Are 1st gens hard for beginners ? Both suspension and motor wise i.e tinkering with the VE pump and all. And I do know a lot about 12 valves as far as upgrades and pump tweaking just never been hands on with one
Old Feb 4, 2014 | 08:29 PM
1stgenctd's Avatar
You could handle it, it's all easy old technology.. get you a manual if you're that worried about it.
Old Feb 4, 2014 | 08:34 PM
birdman01's Avatar
Iv been looking at the sticky thread and found some good videos so hopefully I'll be alright . It'll be my only vehicle so whatever I do it'll have to be done quick. I'm always working and never have personal time so I couldn't take on any high time projects just yet
Old Feb 4, 2014 | 08:52 PM
fordcumminschick's Avatar
You could do what I did and rip the motor out ans put if in a Ford. Great running gear, more can room and a fairly easy project if you're mechanically inclined. I've done 3 now and can have them back on the road in 2 days.
Old Feb 4, 2014 | 09:02 PM
birdman01's Avatar
Funny you said that cause my original plan for this truck is to fully restore it some with me doing the work and some with a shop, then I'll be getting a 7.3 to restore next. Undecided on a obs or 99 and up
