01 Cummins lift pump help
Needing to upgrade my lift pump. Not wanting to go big just something to keep good fuel pressure with a light box. But I think I have an in tank pump. Any help on the pump to get and the process to do it
I would go with a FASS 95gph pump, its up to you if you want filters on that pump or not, obviously the cost is lower without filters. And if you have the in-tank pump you will have to drop the tank. The correct way to delete that pump in the tnk is to buy a liberty tank module from dodge and it is the same sender but no pump in it. Other people delete the pump and make a home made extension so it reaches the bottom of the tank
Renteria1217
Apr 16, 2015 11:38 PM
klein444
Feb 21, 2015 10:33 AM
