Fuel System
Old Apr 20, 2008 | 11:28 AM
jstange2's Avatar
Default Fuel System
What are the advantages of the different aftermarket lift pumps? I was originally looking at the eliminator, but now am wondering if a guy needs something with the 2 filters. Is the stock filter good enough with a low micron filter? Let's hear some advice guys. Thanks.
Josh
Old Apr 20, 2008 | 11:35 AM
DangerousDuramax's Avatar
What you want to look for is a system that not only provides adequate fuel flow but also removes entrained air from the fuel. A single fuel filter is fine and works in conjunction with the stock filter. Most systems have a fuel filter and air/water separator. I personally run the AirDog system and have been quite happy with it.
Old Apr 20, 2008 | 12:39 PM
Wyatt Earp's Avatar
I run 3 filters! The FASS 150.150 with a 144 a 12 and in the OEM cannister a 6. coming up to 5 years and no troubles.
sawyer45306's Avatar
I went with the AIRDOG system basically cause I heard of too many other types of systems not being as dependable. And I do agree the more pure fuel the engine receives I feel is better for performance and efficency. I bought the FP100 model mostly cause I didnt want to mess with taking either the bed off or lowering the tank to put a larger draw straw in. I talked with Pureflow Technologies when I ordered my system and they said unless you are really turning up your engine, the FP100 is well suited for anything I would ever need. I like the style of filters on the AIRDOG and I like the ease of being able to drain water from the system. Also I felt if I am going to invest in a fuel system upgrade like this I want to make sure I have something that should last the life of the truck. Not so sure from what I read and been told the others can do that.
Old Apr 20, 2008 | 01:14 PM
You can't go wrong with either the FASS or the Airdog. Lifetime Warranty on Both!!!
Old Apr 20, 2008 | 08:49 PM
BigGreenMonster's Avatar
walbro here... have not pulled it under 15 with the smarty and a load. i would do it again!
Dbleo351
Nov 20, 2016 09:34 AM
Jet A Fuel
Tech Article Submission
Jun 5, 2015 03:55 PM
Jet A Fuel
Jun 5, 2015 03:28 PM
robbyS
Apr 16, 2015 02:22 PM
moneypitk5
Feb 12, 2015 11:01 AM
