Need help with my 08 6.7 mega cab
Old Feb 3, 2014 | 09:42 AM
Landshark383's Avatar
Default Need help with my 08 6.7 mega cab
Worked all day Friday truck ran great stopped at my dads for 30 minutes when I left the truck started surging and wouldn't go but 5 mph all the way home,(I live like a quarter mile away)no engine light etc. truck is stock with 120,000 miles . After I shut it off and started it back up it seems fine but has me worried now. Thanks for any help.
Drove it today and now light came on put scanner on it has 3 codes
P2262 turbo boost pressure not detected mechanical
P2563 turbo boost control position sensor a circuit range/performance
P0471 exhaust pressure sensor a circuit range/performance
Also turbo has been cleaned recently .
Last edited by Landshark383; Feb 3, 2014 at 09:42 AM. Reason: Automerged Doublepost
Old Feb 4, 2014 | 03:38 AM
97cummins's Avatar
The 5 miles per hour thing sounds like the motor was in a limp mode.
When you said the turbo was cleaned, what do you mean?
It sounds like the turbo is tied in with your running issue.
Old Oct 12, 2014 | 05:27 PM
Desperado1957's Avatar
I've got a 2007 .50 Dodge 2500 4x4 (130,000 miles)with the same trouble codes that you do, but I also have EVIC "Service required, see dealer now". Am interested in whether you got your problem solved and/or what had to be done to resolve. I appreciate any info you can share with me.
Old Oct 13, 2014 | 08:39 AM
coors_man_2005's Avatar
Deletes. Bet your turbo is plugged up. And not letting the vanes move
Old Oct 13, 2014 | 09:41 AM
perk7089's Avatar
Yes probably sooted up without deletes... The egr dumps all kinds of nasty sh*t thru ur turbo! Its disgusting & disgraceful!!! Poor engines eating all there own crap they r trying to get rid of
Old Oct 14, 2014 | 08:49 AM
Motorops's Avatar
FormerVendor
Best bet is to delete that stuff out of the truck and help the engine breath again before you hit catastrophic failure Chances are the vanes are all clogged up which is a common thing for these trucks with the emissions intact .
scubasegt
Jun 9, 2015 12:07 PM
torino73
Apr 14, 2015 11:15 PM
DIESELDENT
For Sale
Dec 19, 2014 06:53 PM
OkieWahoo
Dec 15, 2014 02:15 PM
Jthompson_32
Oct 5, 2014 09:51 PM
