raptor factory replacement pump not primed
Old Jan 31, 2014 | 08:43 PM
AFMX's Avatar
Default raptor factory replacement pump not primed
Installed a new 100 gal raptor pump and can hear the pump run when bump start but no fuel coming out of the outlet side of the pump. Need help bad can't figure out why it won't pull fuel. The truck ran fine before I changed the pump
Old Jan 31, 2014 | 11:46 PM
Bryce's Avatar
Did it have an in tank pump?
Old Feb 1, 2014 | 08:56 AM
AFMX's Avatar
No I checked just block mounted lift pump
Any one know how to reprime the pump that's all it could be because it runs just no fuel movement
Old Feb 1, 2014 | 04:52 PM
Bryce's Avatar
You don't have to prime a lift pump. Add a few gallons of fuel to the tank to make sure your fuel gauge didn't quit on you and try again. Also verify that the fuel lines are hooked up to the correct ports on the pump. Might even try reversing the fuel lines in case the in/out was mismarked. If it still don't pump then I'd say you have a bad pump or a blockage in the tank or line.
HeavyChevy95
Dec 21, 2016 10:36 PM
HardLuck
Jun 24, 2015 08:04 AM
ctjkelley
Jun 3, 2015 06:01 AM
Gm3500
May 7, 2015 11:01 AM
moneypitk5
Feb 12, 2015 11:01 AM
