Need more fuel pressure
Old Jan 31, 2014 | 01:25 PM
JoeJP's Avatar
Default Need more fuel pressure
I bought new 175cc injectors and the company I bought them from said I need to get 65psi
I have blue springed (OEM)
And have resorted to buying a new fuel pump. (Also OEM)
Before the new fuel pump my fuel pressure was bouncing from 15ish to 40PSI
With new fuel pump it's holding steady at idle at ~50 and under load from 45 to 55 (mostly 45)
I have bled it from top fuel filter until diesel came out. Also changed both fuel filters.
Any suggestions to get 65 PSI?
Old Jan 31, 2014 | 05:53 PM
HeavyAssault's Avatar
You should be getting above 55 with the blue spring. Check the fuel pressure gauge and make sure the air is bled out.
Old Jan 31, 2014 | 08:44 PM
JoeJP's Avatar
Can I bleed it out from the gauge it's self. Because I bled it out at the filter.
Old Jan 31, 2014 | 09:41 PM
Adrenaline junkie's Avatar
The line feeding your gauge must be bled also. I mounted a small gauge right off fuel bowl. U can tee off test port and use both if you want to be sure.
Dbleo351
Nov 20, 2016 09:34 AM
robbyS
Apr 16, 2015 02:22 PM
moneypitk5
Feb 12, 2015 11:01 AM
powerstroker13
94-98 7.3L Performance
Oct 30, 2014 02:57 PM
cummins Pride
Oct 6, 2014 11:28 AM
