head gaskets
Old Jan 31, 2014 | 11:52 AM
bajahigh's Avatar
Default head gaskets
can i drive on blown head gaskets as long as i keep coolant in it and dnt let it get to low or let the motor get hot i have no way to work if i have to park my truck
Old Jan 31, 2014 | 12:58 PM
mysterync's Avatar
There's a higher probability of significant engine damage if you continue to drive. You might get lucky, you might not. I can tell you from personal experience that the longer a 6.0 is driven with a blown gasket the more likely it is to see cylinder related issues that require boring. Some of those cases have been by small amounts of water entering the cylinder and some have been caused by overheating. There's obviously other issues that it could cause. Some vehicles may even experience a hydrolock condition. Personally? If you don't have the money to fix it now and you continue to drive it, how will you afford to fix it if a more expensive failure occurs? I wouldn't drive it.
Sent from my SCH-I605 using Tapatalk 2
Old Jan 31, 2014 | 03:08 PM
bajahigh's Avatar
ok are fel pro good gaskets for a 6.0 or is ford the only way to go??
Old Jan 31, 2014 | 04:15 PM
lukesdiesel's Avatar
Ford only
Luke
Old Jan 31, 2014 | 05:51 PM
HeavyAssault's Avatar
Ford OEM gaskets...
Old Jan 31, 2014 | 05:52 PM
mysterync's Avatar
X3 Ford only
Old Feb 1, 2014 | 12:57 AM
bajahigh's Avatar
damn i was gonna put felpro on the shops tab and get it done a lil faster since i dnt have the money right away but ok ill save for ford
Old Feb 1, 2014 | 04:10 PM
If you don't use OEM you will be doing it again
Luke
TheMacster
5.9L 24V Performance
Apr 14, 2015 07:01 PM
klein444
6.2L & 6.5L Performance
Apr 14, 2015 09:04 AM
Vmason
Jan 21, 2015 11:33 PM
Adam65
Jan 9, 2015 11:50 PM
Hardcorefx4
Oct 6, 2014 07:47 PM
