01 cummins reading no bus... any help??
Old Jan 30, 2014 | 07:59 PM
reed745e's Avatar
Default 01 cummins reading no bus... any help??
my 01 cummins reads no bus where the mileage is displayed, over head computer where outside temperature and mpg are displayed reads ccd (Chrysler collision detection), none of the gauges work my fass system wont kick on and its not getting fuel to cylinders 1,2 and 3 wile cylinder 4 gets plenty. could the issue be in the ecm or wires around it?
Old Jan 30, 2014 | 10:03 PM
ramrunner01's Avatar
I would check all connections at the fuse box make sure there are no wires shorting out or open copper
Old Jan 31, 2014 | 07:55 AM
reed745e's Avatar
already did. their all good
Old Feb 3, 2014 | 10:26 AM
fsmyth's Avatar
Check your relays. Generally a fuse, but sometimes the relay.
The lift pump is the main clue - you are probably not getting power to
the ECM.
Other than that - check all wiring. I know it's a pain, but one short will
kill the whole bus.
Old Feb 3, 2014 | 11:41 AM
mysterync's Avatar
Do a voltage drop test to the pdc with the key on, then move to ecm and pcm power supplies and do a voltage drop there. Agreed that it a likely ecm or pcm not getting a clean 12v. Could also be ground related but I'd check there after the power supply circuits. Could be a short or break in the bus circuits as well, and just as easily a failed computer.
Sent from my SCH-I605 using Tapatalk 2
Cody Cain
Dec 22, 2014 01:27 PM
Cody Cain
Dec 21, 2014 06:50 PM
Oct 31, 2014 08:10 AM
Oct 24, 2014 04:40 AM
Omingnome
Oct 20, 2014 12:25 PM
