Dead injection pump VP44
Old Jan 29, 2014 | 12:09 PM
stan beavers's Avatar
Default Dead injection pump VP44
This truck was running good until it hit a deer. The next day it quit. A diagnostic test and it gave a death code on the injection pump. The truck has 136,000 miles on it. It hard for me to believe the injection pump went out on it. It will crank with ether. I cracked a line at the pump and it seems to be getting fuel. This is a 1999 Ram 2500 5.9 cummins. Any ideas? Is there a reset? There is not a pump in the tank, it's on the side of the engine. Any help would be greatly appreciated.
Old Jan 30, 2014 | 09:54 AM
Devon527's Avatar
Try to clear the code and crack the injector lines at the head, I usually do 1, 3, and 4 and crank for about 20 seconds. Tighten back up when you see fuel coming out and then crank for another 20 seconds. But it is not uncommon for that mileage to have a bad injection pump, I've seen far less miles and the pump go out.
Old Jan 31, 2014 | 08:46 AM
jkidd's Avatar
Call in we can go through the trouble shooting steps. a new vp44 is less than $1000 delivered
Old Jan 31, 2014 | 06:14 PM
cerickson's Avatar
Pumps could go out at any time with these vp's. Mine went out with only 110,000 miles on it. Its the weak link to these years of trucks.
Old Jan 31, 2014 | 07:20 PM
BarryB's Avatar
The real weak link is the factory Lift pumps. They do not supply the VP with enough fuel pressure to keep the electronics cool on the VP pump. When they get weak, they cause the VP to over heat, and burn out ... Upgrade to an raptor or airdog lift pump, install Fuel pressure gauges you will be set. For the O P give JKidd a call betcha he'll get you straightened out.
DeLuzGN
Mar 17, 2015 08:08 AM
nelly559
Feb 17, 2015 06:49 PM
moneypitk5
Feb 12, 2015 11:01 AM
letters4and18
Dec 11, 2014 12:03 PM
rtbcoop
Nov 29, 2014 11:33 PM
