Lift pumps
Old Jan 28, 2014 | 07:53 PM
slowboogy's Avatar
Default Lift pumps
Anyone have any inputs on lift pumps? How big of a lift pump for stock turbo? And how hard is it to install
Old Jan 29, 2014 | 10:00 AM
Devon527's Avatar
It all depends on what you have right now and if you plan on upgrading power in the future or not. I have a FASS 95gph filterless pump on my 99 and it works jsut fine but I am thinking of upgrading to a 150 with filters. They are relatively easy to install its just more time consuming than anything. Took me about 2 1/2 hours to do mine.
Old Jan 30, 2014 | 02:27 PM
#2power21's Avatar
a 95 gph is perfect for stock to mildly modified and are easier to install .if you go with a 150 or bigger most kits run 1/2 lines with draw straws . I just recently installed an air dog 150 on my 01 Cummins and it took about6 hours due to having to drop the tank.
Old Jan 30, 2014 | 05:14 PM
GSP7's Avatar
Id avoid pureflow products/Airdog/raptor. Do a search of all the problems and failures people have with those
Fass seems to have good reviews
Old Jan 31, 2014 | 12:08 PM
jigabop's Avatar
fass 95 or 150 titanium series
Old Jan 31, 2014 | 06:09 PM
cerickson's Avatar
I have a fass 95 with a small inline filter that goes to the stock filter housing. Good pump, plus you get a good warranty with it. Get a fuel pressure gauge while your at it.
Old Feb 2, 2014 | 09:00 AM
slowboogy's Avatar
Will a fass 95 let me roll a little on those ricer **** if need be?
Old Feb 2, 2014 | 10:44 AM
cerickson's Avatar
Yes, it will do just fine with the stock turbo and injectors. I run an edge comp box with mine. At wot the pressure drops down to 12 psi. You should get you a fuel pressure gauge if you don't have it yet.
Old Feb 4, 2014 | 05:50 PM
JKnight's Avatar
It looks like fass 95 is the way to go but if I decide to do injectors later will it still work fine? I'm new to the board and this is the first I've heard of lift pumps. I want to do mild modifications to give my truck a little more ***, but that's about it for now.
Old Feb 5, 2014 | 12:27 PM
jigabop's Avatar
drops to 12psi?
sounds like you don't have the pressure set very high...
I have my lift pump set to 20psi idle and it drops to 16psi under 100% fueling @ WOT
that's with a 150GPH pump and 1/2" line 1/2" draw straw.
landon025
Sep 8, 2015 09:21 PM
klein444
Feb 21, 2015 10:33 AM
moneypitk5
Feb 12, 2015 11:01 AM
Callmecowboy
18
Feb 3, 2015 09:01 PM
Callmecowboy
Jan 22, 2015 04:39 PM
