12 valve cummins swap into suburban
Old Jan 26, 2014 | 10:10 PM
waystro's Avatar
Default 12 valve cummins swap into suburban
Ok I have some questions about doing a 12 valve swap into my 1997 suburban.
Can I use my suburban wire harness/computer/ do I need my computer.
Can I use my master cylinder/brake booster/powersterring pump.
What will I need to do this swap. Any thing I'm leaving out any help is great Thanks
Oh and if I go with a manual trans do I need to get a new steering coluame(it's a automatic)
Old Jan 26, 2014 | 10:28 PM
mdub4life29's Avatar
4btswaps.com is the place to go!! tons of Info on there
Old Jan 29, 2014 | 05:40 PM
Edahall's Avatar
You'll need to retain some of it so you can have a functioning dashboard.
The Cummins has a vacuum pump that's adequate to supply the brake booster. However, a hydrooost system would a nicer way to go.
Use the Dodge power steering pump.
Are you going to be putting on a lift kit? Keeping it stock height is possible but there might be interference problems with the front differential (if your Suburban is 4x4). Yes there are ways around this issue.
You won't need another column if you're going with a manual transmission. Just remove the shifter handle off your current column.
What gears do you have in your Suburban?
Old Jan 31, 2014 | 11:01 AM
waystro's Avatar
Gears are 410 I think. I'm going to use my 480LE transmission. How to wire this all in is the biggest thing. It's a 2wd. It has a hydro boost on it
Old Feb 2, 2014 | 03:35 AM
u2slow's Avatar
Your 4L80E will need a controller. I am unsure if the standalone controller from 91-95 diesel vans will work with a later 4L80E.
IMO, get a Dodge/cummins donor truck and swap the entire powertrain. Should be able to rustle something up for $1-2k if you look hard.
4.10 is a deep ratio to run with the cummins due to the lower rpm range (i.e. 3000max) Not ideal unless you are towing large, or wish to run huge tires. Another reason to find a parts truck. Most are 3.54.
12 valve 97
5.9L 12V Performance
21
Jan 27, 2016 04:59 PM
ILLUSHA
Diesel Engine Conversions
10
Aug 21, 2015 05:48 AM
Bowtie_Cummins
Aug 7, 2015 12:08 PM
Stone007
Tech Article Submission
Jul 3, 2015 01:28 PM
Radioking1777
Jun 8, 2015 10:26 PM
