245 hp 01 misfire cylinder new pump new injector good compression
I installed a new ip and have had white smoke and a misfire in #1 cylinder. Replaced injector to see if that was it. Still nothing, finally got around to compression which i did 1 and 2 to get a good and bad reading. Both read about 475 psi. No idea what to check next.
Forgot to mention its an 01 6spd 3500
Last edited by davidthomas; Jan 26, 2014 at 12:08 PM. Reason: Automerged Doublepost
I'm guessing your using a injector kill test to determine which cylinder. Typically if there's a misfire caused internal mechanical issues it will show in compression or leak down test but just for poops and giggles do you have any blow by? Did the misfire occur after the injection pump replacement? Or was it already occuring?
Sent from my SCH-I605 using Tapatalk 2
It happened afterwards, but it was sitting a while before a new pump was put in. I tested the injectors to see if the one i bought was bad so i switched 1 and 3 and checked and #1 still misfires.
