throttle problems any ideas?
Old Jan 25, 2014 | 11:03 PM
goinhuntin's Avatar
Default throttle problems any ideas?
I have an 01 cummins stock expect 4inch exhaust and intake and just had the lift pump and injector pump replaced. I have been to a few shops and nobody can figure this out, now at around 2000rpms about 70 on the freeway cruising on flat ground everything is fine than I try to give it a little throttle to speed up I lose power, I can back off the throttle and have power back or go more than half throttle and have power so it feels like a dead spot.. if that makes sense. the only time I can really notice it is on the freeway and the volts on the tps seem to be normal. hopefully I explained it good enough!
any help I would really appreciate it thanks!
Old Jan 26, 2014 | 10:11 PM
jrconsultid's Avatar
Default throttle boost specifications
How much boost is your truck showing while this symptom occurs?
FYI -- The wide open throttle boost specifications: standard engine, 22-24 psi;
HO engine 25-26 psi.
Old Jan 26, 2014 | 10:31 PM
goinhuntin's Avatar
just before the symptom im at 6-8psi than drops to 3 or less when I hit the dead spot
and wide open I can only hit 17-18psi
363coupe
Nov 4, 2015 09:41 AM
Blair@BD
BD-Power
Sep 10, 2015 12:29 PM
94deisel
May 11, 2015 10:17 AM
Ol Goat
Jan 22, 2015 02:16 AM
1stgenswap
Nov 3, 2014 09:45 PM
