5 speed turbo's
Old Jan 23, 2014 | 10:24 PM
DevonMolendyk's Avatar
Default 5 speed turbo's
Im looking to get a new truck and im looking for a manual. I know that 6 speeds come with a HX35 but I don't know what the 5 speeds come with. Can someone please help me. thank you
Old Jan 23, 2014 | 10:32 PM
RAW's Avatar
RAW
I believe the 98.5-00 all had HY's. In '01 they put the HX's on manuals.
Turbocharger FAQ
Turbo info for Dodge Cummins on that link.
Old Jan 24, 2014 | 09:25 AM
98cummins's Avatar
Is one better than the other? I am also curious about a jacobs exhaust brake, my new truck has one but doesn't appear to work anyone know anything about these?
Old Jan 24, 2014 | 09:41 AM
Devon527's Avatar
My 99 5 speed came stock with a hx35, with my set up I can spike it to about 50psi so its time to upgrade
Old Jan 24, 2014 | 11:14 AM
jigabop's Avatar
um...no.
All manual trucks had the hx35 on the 2nd gen 24v.
early automatics (98.5-00) also had the hx35. 01-02 autos had the hy35.
turbo specs:
hx35: 56/60/12
hy35: 56/58/9
Old Jan 24, 2014 | 04:11 PM
RAW's Avatar
RAW
I guess the information in the link is incorrect, or I misinterpreted it.
Old Jan 24, 2014 | 06:07 PM
jigabop's Avatar
HX35w is the better turbo for increasing power over stock levels as it's turbine wheel and turbine housing are larger which allow for more exhaust flow and lower drive pressures.
You don't want too much drive pressure or you can end up popping a head gasket or damaging the turbo.
Exhaust brake is a pretty simple device. it is a butterfly with a hole in it that closes when you turn on the exhaust brake and let off the throttle. it intentionally restricts the flow of exhaust by 75%+ to make the engine harder to turn over because of the exhaust restriction essentially causing the engine to work like an air compressor.
this aids in slowing down the engine RPM quickly and as a result, slows down your vehicle quicker without using the service brakes.
The jacobs brake is vacuum operated.
This should not be confused with a compression release brake, as that is a whole different type of braking system that works off of the exhaust valves by releasing the compression after the compression stroke. (not available for the 5.9L engine)
cjt8569
Sep 29, 2015 06:39 PM
Dertyd
24
Jun 7, 2015 02:45 PM
May 17, 2015 12:10 PM
F250MACH
Apr 26, 2015 05:19 PM
offroad00
24
Oct 23, 2014 03:28 PM
