6.0 oil leak
Old Jan 21, 2014 | 06:43 AM
anton57's Avatar
Default 6.0 oil leak
oil puddle under truck, help ,2006 . 6.0
lot of oil leaks as soon as I start the engine, went underneath and noticed it coming down from top right side,,
Old Jan 21, 2014 | 11:25 AM
bobfbigman's Avatar
check the top of turbo for the oil feed line. Also look straight down on top of motor right next too and also right behind the oil filter housing at the 2 sensors, the oil pressure sensor behind the the filter housing and the oil temp sensor to the left of the housing. the oil pressure sensors have been known to fail and oil pour out the top of them. the leak is going to be up top, sometimes it is easier to find the leak when it is dark out and you use a flashlight to find the leak, you can focus in on an area better.
Old Jan 22, 2014 | 09:17 AM
anton57's Avatar
Thanks for the big help, greatly appreciated, I,ll wait for a little warmer weather, minus zero now , in N.Y. , no garage,
cummins Pride
Sep 28, 2015 12:11 PM
Gomerpile79
Apr 9, 2015 03:45 PM
pro graphic solutions
Feb 10, 2015 03:48 PM
ash23k
Dec 30, 2014 08:31 PM
iam1746regan
Dec 21, 2014 05:06 PM
