Why does my 2000 24V Cummins not exhilarate past 30mph???
Old Jan 18, 2014 | 01:03 PM
Txpipeliner's Avatar
Default Why does my 2000 24V Cummins not exhilarate past 30mph???
HELP!!!
I cant get my rig to go more then 30mph and I've changed my filters etc. what can be causing this? Any and all feedback is appreciated.
Old Jan 18, 2014 | 01:04 PM
CR9712v's Avatar
does it blow alot of smoke?
Old Jan 18, 2014 | 01:06 PM
No it dont...
Old Jan 18, 2014 | 01:08 PM
CR9712v's Avatar
might end up being your tranny.. how did your tranny fluid smell and look?
Old Jan 18, 2014 | 01:12 PM
oil is perfect where it needs to be think its tension pulley
sqeaks but belt is new
Last edited by Txpipeliner; Jan 18, 2014 at 01:12 PM. Reason: Automerged Doublepost
Old Jan 18, 2014 | 01:21 PM
CR9712v's Avatar
have you hooked a scanner up to it?. could even be a lift pump not getting adequate pressure. if it was a tension pulley pulley going bad youd probably see more signs, it'd be harder to start, truck would overheat, power steering would slowly go out.
Old Jan 18, 2014 | 01:27 PM
no i havent but good idea gonna have too thanks for your help greatly appeciated
Old Jan 18, 2014 | 01:28 PM
CR9712v's Avatar
Old Jan 18, 2014 | 02:23 PM
mysterync's Avatar
Tensioner pulley won't cause acceleration issues. Think I'd start with fuel pressure, dtc's, get some boost numbers and graph the apps. The tensioner pulley may be loosing a bearing. You might loose engine cooling, ac and charging system but power steering won't be effected
Sent from my SCH-I605 using Tapatalk 2
Old Jan 19, 2014 | 12:00 AM
Irish_Alley's Avatar
we had one do this, but it would be ok once it warmed up and if you turned it off and back on. replaced injection pump and its all good.
