coolant disappearing? no leaks visible? help please
Old Jan 18, 2014 | 12:38 PM
sickopstrokefan's Avatar
Default coolant disappearing? no leaks visible? help please
So with my truck on stock tune I dnt lose coolant. But any kind of tune I put on, I lose it. If boost pressures exceed 20lbs. Trucks completely bulletproofed. Bad gasket job? No I dnt hav coolant coming out of degas bottle. No leaks. When parked on cement this truck has zero leaks. Where does coolant go and how/why????
Old Jan 19, 2014 | 05:36 PM
tiremann9669's Avatar
It goes out the tailpipe
Old Jan 20, 2014 | 05:09 AM
How does it get into pressurized chamber? Cracked head? Airpocket?
Old Jan 20, 2014 | 10:47 PM
Mx180's Avatar
Mine did the same thing and I never figured it out... I would like to know the answer as well
Old Jan 25, 2014 | 09:53 PM
CND.powerstroke99's Avatar
My shop i go to can possibly help you over the phone and point you in the right direction . Call dagger diesel performance in Calgary alberta canda - they have pin pointed everything I ask over the phone good quality honest shop
Old Jan 26, 2014 | 10:23 AM
1998.5speed's Avatar
Seems like a head gasket is leaking into the cylinder and burning off the coolant . which is why you don't see it
Old Jan 26, 2014 | 12:54 PM
Cjasso78's Avatar
I agree with the bad head gasket theory, I have seen it happen. The coolant burns off in the exhaust, depending on how bad it is you might be able to see some light white smoke.
Old Jan 27, 2014 | 08:41 AM
bigred91's Avatar
I would check the heater core before I went through with new headgaskets. It probably is head gaskets, but the heater core takes 5 minutes to get to in these trucks so it couldn't hurt to check.
duramax on fire
Chevy/GMC Duramax 01-04 LB7
11
Aug 14, 2017 09:51 PM
caissiel
Sep 24, 2015 05:37 PM
ramrunner01
10
Dec 2, 2014 11:34 AM
97f-250
Nov 23, 2014 08:08 PM
gmcmanis
Nov 9, 2014 04:49 PM
