6.7 automatic will not manually shift
Old Jan 17, 2014 | 10:52 PM
nomadcattle's Avatar
Default 6.7 automatic will not manually shift
dads 08 6.7 3500 auto can't be manually shifted, switch does nothing, fuse?switch?karma? CK Eng symble now lit, just got truck, he doesn't know if it worked before see dealer now message came and went. Thanks for any help.
It didn't manually shift before message ether , is there a fuse? Bad rocker switch? Tried in/out of tow setting. Any help, clues, or ''had same problem'' appreciated . Thanks
Last edited by nomadcattle; Jan 17, 2014 at 10:52 PM. Reason: Automerged Doublepost
Old Jan 24, 2014 | 10:16 AM
Posted on different site, was told no fuse probley switch, which dealer can ck resistance on while switching. new aproxametly $35
Old Jan 26, 2014 | 02:07 PM
RamBow3500's Avatar
I don't quite understand your question,are you saying it won't go in and out of tow mode? Is it a 68RFE? If so there is no manual gear change available its PNRD...Or are you talking about the 2w 4w 4wlow selectors...
Old Jan 28, 2014 | 01:11 AM
The toggle switch on the face of the gear lever ''should'' give you 6 thru 1 gear, click down, down shift, click up, up shift. Tow works, and is the button on the very end. Shifter switch is closer to steering wheel and faces you, Its neat when it works, just like formula one paddle shift, but totally different
Old Feb 9, 2014 | 07:47 PM
Kcfranqui's Avatar
It doesn't manually shift the transmission. It sets the MAX gear that the tranny will go into. It will still shift down as needed...it just won't go higher than you select.
Old Feb 10, 2014 | 09:34 AM
yep, that's why I said totally different, Humor, it works just like all automatics , except the switch doesn't work, got to replace. But thanks, your hearts in the right place, peace/out
Old Jun 29, 2014 | 08:06 PM
vexxxed's Avatar
So the rocker switch was bad? I'm having the same problem.
2008 Dodge 2500 6.7 4x4 Automatic
1995 Dodge 3500 12 Valve 4x4 Automatic
1991 Dodge D250 non-intercooled 2WD
Old Jul 2, 2014 | 09:26 PM
yep, but the switch is part of the shift lever, whole assembly.
Old Jul 4, 2014 | 10:09 AM
vexxxed's Avatar
Oh cool thank you.
Old Jan 15, 2017 | 09:10 PM
Frose48's Avatar
Anyone else with this same problem contact me I can repair them for considerably less than a new lever.
