VP44 to P-Pump converison cost?
Old Jan 15, 2014 | 09:32 PM
Cumminsambitionist's Avatar
Default VP44 to P-Pump converison cost?
Hi Yall, recently I was on a road trip, and long story short, my lift pump was failed and my vp44 was toast too. So i replaced the vp44 from industrial injection and i put an airdog 100 lift pump. When this happens again as I now know these are a weak link. I was wondering if anyone here had done a conversion to a p-pump and what it actually costs after the kit and the pump. And will my airdog 100 be sufficient to fuel my p-pump?
Old Jan 16, 2014 | 11:32 AM
jigabop's Avatar
Cummins Performance Parts CPP P7100 Conversion Kit 24v [Convert 24v to p-pump]
there is a kit with pretty much everything you need other than the injection pump itself...add another 1500 or so to that for the injection pump...
you can also convert to VE pump. not near as powerful, but allows you to keep the variable timing.
usually can buy a core pump for a few hundred and use that as the core to buy a pump...
Old Jan 16, 2014 | 11:00 PM
So will the airdog 100's 15psi fuel pressure be enough to fuel p-pump?
Thanks
Old Jan 17, 2014 | 07:08 AM
mysterync's Avatar
Thanks
No you'll either need to raise the pressure via the regulator (depending on which air dog) or switch to a p-pump air dog setup.
Sent from my SCH-I605 using Tapatalk 2
Old Jan 17, 2014 | 11:50 AM
jigabop's Avatar
you'll want a 40psi spring for the regulator
Old Jan 17, 2014 | 05:34 PM
turbo2332's Avatar
why did you spend $2k on a new pump and fuel pump just to spend somewhere in the neighborhood of $3500 more? your vp44 will last 100's of thousands of miles if you keep fuel pressure to it and in most cases be much more friendly on the road if your truck is making more than stock HP.
HardLuck
Jun 24, 2015 08:04 AM
ctjkelley
Jun 3, 2015 06:01 AM
Gm3500
May 7, 2015 11:01 AM
DeLuzGN
Mar 17, 2015 08:08 AM
moneypitk5
Feb 12, 2015 11:01 AM
