coolant problems
Old Jan 14, 2014 | 12:18 PM
bajahigh's Avatar
Default coolant problems
ok im overheating loosing coolant coolant steaming outta the radiator and the heater core hose by the alternator never had coolant issues this bad before i changed the degas bottle out old one was leaking all over the place also i have no heat at all also ive been low on coolant and when it gets hot n i relase some pressure in the degas bottle n take the cap off coolant will rush back in to the tank then drain back down into the block
so whats the problem here?? ive been told blocked heater core thermostat blender doors egr cooler head gaskets kinda neeed help to narrow it down thanks
Old Jan 14, 2014 | 06:17 PM
Adrenaline junkie's Avatar
Is thermostat stuck closed??
Old Jan 15, 2014 | 04:51 PM
bajahigh's Avatar
possibly havent looked into it yet also when i loosen the degas bottle cap it magically fixes everything i have a lil more heat wnt over heat and wnt loose coolant will run like a dream
Old Jan 18, 2014 | 12:33 PM
sickopstrokefan's Avatar
Try thermostat change first. Very easy and cheap.
Old Jan 19, 2014 | 05:40 PM
tiremann9669's Avatar
Theres a reason the 6.0 tech section is the busiest section of the site
Old Jan 24, 2014 | 09:57 PM
detroitdiesel idi's Avatar
Head gaskets arp studs oil cooler and new coolant cap n ull b set
duramax on fire
Chevy/GMC Duramax 01-04 LB7
11
Aug 14, 2017 09:51 PM
caissiel
Sep 24, 2015 05:37 PM
Mike0885
Feb 28, 2015 03:16 PM
97f-250
Nov 23, 2014 08:08 PM
gmcmanis
Nov 9, 2014 04:49 PM
