Headlights issues
Old Jan 14, 2014 | 03:00 AM
shovelhead87's Avatar
Default Headlights issues
I was coming home from work this morning and all of a sudden my headlights turn off but all my markers and dash lights are still on. I replaced the headlight switch about a month ago with a BWD switch the plug was not melted. It wasn't the bumps in the road when I finally found the side of the road my headlights were still flickering on and off where should I start looking is it maybe a relay
Old Jan 14, 2014 | 03:50 AM
97cummins's Avatar
Yes, check the relay. Then I would start checking the wiring from the headlights back, and see if you find a wire rubbing against something or a short.
Flickering on and off sounds like a loose ground or ground issue.
Old Jan 14, 2014 | 03:58 AM
I will check it out in the morning thanks
Old Jan 14, 2014 | 04:56 AM
the.beard's Avatar
Originally Posted by shovelhead87
...when I finally found the side of the road my headlights were still flickering on and off...
Not a relay. If a relay goes, the lights don't flicker. You already got some sound advice; checking the wiring for an intermittent ground is a good idea. I'd wager your new switch failed, though. Borg Warner (BWD) used to make high-quality parts before they were bought out by SMP Global. Now that switch you just replaced is Chinese-made and unreliable at best. I've had two BWD VSS failures in as many months on the second gen.
Just something to chew on while you chase wires.
Old Jan 14, 2014 | 01:30 PM
u2slow's Avatar
When I had headlight problems it was the highbeam/signal switch in the column. I didn't have time or $$ to get a replacement, so I broke out the relevant wires from the switch and extended them to an oldschool floor mounted pushbutton.
I still havent changed the column switch....
Old Jan 14, 2014 | 05:57 PM
the.beard's Avatar
Listen to this guy ^. I did this before I had problems with the column switch. Heads off the BS at the pass and it's so easy a woman could do it.
Old Jan 17, 2014 | 10:51 PM
It's been 3 days and I have had no issues after I changed the switch. Going to run through the wires and grounds just to be safe this weekend
dwmeehan
Jan 29, 2025 12:13 PM
culp7
14
Jul 20, 2015 10:13 PM
carid
Diesel Bombers Sponsors
Apr 7, 2015 07:30 AM
ronstop
Feb 26, 2015 09:48 AM
Polaris04
Dec 1, 2014 08:27 AM
