2006 cummins 4wd popping out
Old Jan 13, 2014 | 06:25 PM
Casinoguy616's Avatar
Default 2006 cummins 4wd popping out
2006 ram 2500 popping in front. I have a 2006 dodge ram 2500 cummins quad cab short bed 4wd. Every time I put it in 4wd or 4lo it will pop out. The light will stay on but when I let off the accelerator it will go back in. I don't know where to start and have been reading other forums trying to get some where to start. Help please as it is winter and I live on a hill and tow trailers.it is an automatic with the automatic 4ed turn dial.
Old Jan 14, 2014 | 10:59 AM
steved's Avatar
The shift solenoid is likely failing...when I still owned one, that was a known problem on the electronic shift versions.
Old Jan 14, 2014 | 11:33 AM
How would I find a new one? I have been looking online and can't find any type of solenoid.
Last edited by Casinoguy616; Jan 14, 2014 at 11:33 AM. Reason: Automerged Doublepost
Old Jan 14, 2014 | 01:42 PM
steved's Avatar
2006 DODGE RAM 2500 PICKUP Motor
Looks like they term it a "motor"...
I would suspect the "motor" or the actual switch is likely your issue. Maybe start by pulling the connectors off the "motor" and see if you have any corrosion or the like.
Old Jan 14, 2014 | 01:44 PM
Awesome. Thank you!
Old Jan 17, 2014 | 06:27 PM
Ok, I replaced the transfer case motor and it still have the same problem.
Old Jan 17, 2014 | 06:58 PM
mysterync's Avatar
The actual diagnosis calls for using an oscilloscope to watch the motor function. The mechanical system can't be diagnosed until the electrical side has been verified.
Sent from my SCH-I605 using Tapatalk 2
Old Jan 17, 2014 | 07:20 PM
Ok. Well I'll try and talk to a few guys and see what they say. I'm just hesitant to taking my truck to a shop and 1,000 dollars later it still isn't fixed. But it's starting to look like I won't have a choice. Thank you so much for your help though!
Old Jan 17, 2014 | 07:30 PM
mysterync's Avatar
A good shop won't do that. A good shop will be able to provide you with data to prove why it's not working and why their fix will work. Sometimes a shop a have no choice but to take a gamble but before doing so they should consult with you and make sure you understand the possibility of the repair not being the fix.
nathanmueller
Diesel Engine Conversions
Sep 8, 2015 03:30 PM
Arog223
Aug 16, 2015 07:15 PM
Zachbishop
May 29, 2015 07:21 PM
regitan
Big Rigs & Semis
May 24, 2015 10:23 PM
Sbboozer
Nov 16, 2014 05:52 PM
