My temp gauge goes to 190 then back down to 150ish
Old Jan 11, 2014 | 10:01 AM
Hotrodd_67's Avatar
Default My temp gauge goes to 190 then back down to 150ish
While driving my temp gauge goes up and down.and heat never gets hot just warm.new thermostat
Old Jan 11, 2014 | 01:38 PM
Pclem's Avatar
Mine died the same thing, only difference is my heat blows hot as hell
Old Jan 11, 2014 | 02:00 PM
the.beard's Avatar
You've got a bad thermostat or a whole lot of air in your cooling system.
Old Jan 14, 2014 | 09:18 PM
mysterync's Avatar
Betcha money a cummins thermostat will fix it. We see a lot of folks installing stants and come to us with this problem.
Sent from my SCH-I605 using Tapatalk 2
Old Jan 15, 2014 | 12:52 PM
Pclem's Avatar
what about having this issue before the tstat was replaced like on my truck?
Old Jan 15, 2014 | 01:26 PM
mysterync's Avatar
Could be a number of things. Anytime you have wide fluctuations that are persistent we would look for as mentioned above air in the cooling system, air entering the system via a leak (pretty rare with these trucks) or possibly a faulty gauge. In theory a water pump can cause it but unless the fins are missing a faulty pump is pretty hard not to notice. In very cold climates a big cooling system will experience variations.
I would start with a coolant funnel and verify there's no air in it and move from there. Obviously a faulty thermostat could cause similar issues as well.
Old Jan 15, 2014 | 11:11 PM
Pclem's Avatar
So I've replaced my thermo,added an aftermarket gauge, and water pump seems fine. I will give the funnel trick a shot.
Old Jan 16, 2014 | 06:35 AM
mysterync's Avatar
Did you use a cummins thermostat?
Old Jan 16, 2014 | 09:41 AM
Pclem's Avatar
no, i used a failsafe from autozone, that way if it does fail it will fail open
Old Jan 16, 2014 | 10:40 AM
mysterync's Avatar
We sure do replace a bunch of the fail safe thermostats in otherwise normally functioning cooling systems. Might be wise to do some research on those thermostats and you might find that they cause more trouble than their worth!
Did the thermostat you installed have the "jiggle" valves? They say they have a "bleed notch" but they just don't work well. Often cause drastic temperature swings. If I were in your shoes I'd order a cummins thermostat and see if that fixed my problem.
JDurks2
16
Jun 7, 2015 08:57 PM
doodieroot
May 10, 2015 11:48 PM
99stackedpowerstroke
Feb 7, 2015 10:58 AM
