53 Block
Old Jan 9, 2014 | 11:32 AM
Razdad's Avatar
Default 53 Block
I bought my truck as a present to myself for Christmas from a family friend and looked and found out it has the dreaded #53 Block the truck had maintaince records from 140,000 to when I bought it with 199,000 and there have been no problems so far.I changed oil and fuel filter at 200,000 and in the 2,000 miles I have drove it has never got above 190 degrees.The truck has been taken care of& has car fax report in it.I planned on Bombing it out but want to know everyone's opinion on that 53 block first.The man I bought it from said he replaced lift pump and Clutch(I don't know what brand of parts he put back on truck or at how many miles the truck had on it when he replaced Lift&Clutch)The build date on this truck is 04/1998 and was assembled in Mexico(What I have heard and read #53 blocks came from Brazil)My cousin has same year model of truck 98.5 he bought 6 months ago with 126,000 and his lift pump went out at 132,000(he put in aftermarket lift pump in)then at 136,000 his injection pump has went out!He paid a lot more$ for his truck because of low miles and his is Quad cab shortbed 4x4 where mine is Extended cab Longbed 4x4.This is my first Diesel so any help is appreciated on what steps I can take so this don't happen to me!
Old Jan 9, 2014 | 09:20 PM
jrconsultid's Avatar
Default What is the "53" block?
The "53" comes from a casting number on the side of the block and is used to identify the problem blocks. Supposedly it affects about 100,000 blocks, but not only in Dodge Rams. Here is information regarding the castings from a thread on TDR:
Copied from: 2001 cracked block
1. Brazilian Blocks are cast by a company named "TUPY" and are marked such. They are identified with cast evolution numbers. #53's are TUPY's. #54 and later evolutions were improved to correct the block issues that the 53's had.
2. Mexican Blocks were made by "Teksid" these blocks to my knowledge never had a problem with cracking, as they are heavier duty by trait, but they did follow the evolutions and got thicker. These blocks do not have the 2 digit "cast number" embossed on the side, instead a series of numbers that are unidentifiable to me. The Mexican blocks were rumored to even be harder to machine do to a harder cast overall, basically better quality in my opinion.
Brazilian Tupys always seem to outnumber Mexican blocks during the ISB's production probably about 8 to 1. So basically if there is a pattern number its Brazilian, if there is a series of small numbers its Mexican.
By the way the Mexican equivalent of a 56 pattern was the Heaviest ISB block of all. This means if you have a 2002 without a #56 on it and instead it has a series of numbers that are smaller and hard to identify, you got the the big boy!!!
Why the Worry?
Simply, the worry is that the block will crack. These blocks have thinner water jacket walls than other blocks so with coolant cavitation, corrosion, coolant pressure in the block, and torque, they may crack, spilling your coolant. I know from experience that it will not blow up the engine, but you will see that temp gauge rise more often than you'd like.
Who Should Worry?
Those owners of a Cummins 24v ISB engine in a 1998-2001 model year vehicle. This does not only affect Dodge Rams. The 53 block was also used in medium duty trucks from different manufacturers, mobile homes, public school buses and mass transportation buses.
Update: Recent information I have received from a 1998 12v owner says that some late 12v engines have "53" blocks. This owner knows because he HAS one. His truck has a build date of 11-97. He did say, however, that he has had no problems with his block, regularly pulling heavy trailers in the Rocky Mountains.
How Do I Find out?
If you want to see if your engine block could be one of these dreaded "53" blocks, crawl under the front, left side, and look up at the block on the front, directly under the injector pump (by the PS pump). You should see a large wiring harness mounted to the block. Directly below this, just above where the oil pan meets the block you will look for a "53" cast in the block. The numbers will be about 1 inch tall. See picture below:
Note: I have heard of some cases where the "53" is elsewhere on the block, but I have not been able to verify any other locations or see them. I now have proof of another location where a "53" can be found.
What Happens?
A crack develops on the right side of the engine, below the freeze plugs, right where the block bends back towards the inside of the block. It is a difficult area to see for auto transmission owners as it is directly behind the transmission heat exchanger. At first everything evaporates so there is no spot under the truck, but you may notice a coolant odor. The leak doesn't occur at idle in most cases because the crack is tight to get through, and doesn't leak until the RPMs of the engine are up, with the water pump causing higher pressure inside the engine block due to the restriction of the thermostat.
The crack will grow over time and you will go through coolant faster. I found that I lost coolant at a slower rate if I let the engine warm up for a while, so the thermostat opened and lessened the pressure inside the engine block.
When Might It Happen?
This crack begins when towing in most cases. I have seen modded trucks that did not leak until they were stressed from towing heavy loads in the mountains. These same trucks would put in several runs at the drag strip on a regular basis and never had a problem, even towing, until they towed in the mountains. This is how my crack happened. I towed my tractor on the basically flat land around my home (minimal rolling hills) and I had not experienced a problem until after I had towed my tractor in the Blue Ridge mountains of Virginia (for those of you who don't know, these ain't very big mountains when compared to the Rockies). The load was about 8,500 lbs + the 6,900 of the truck.
What Do I Do If I Have A Cracked Block?
This depends on a lot of things. In the first scenario, you have a stone-stock truck with less than 100K, and is less than 5 years old. In this case, just take it to the Dodge dealer and let them put a new short or long block in (they will decide which they put in), free of charge. If you don't have any other problems with the internals of your engine you might ask them if they will just replace the block with the latest design ISB block, the "Storm" design. Reasons for this will become clearer later in this article.
If you have no engine mods, but have added gauges or upgraded the transmission in a manner that is evident to the naked eye, you will likely get some flack from Dodge about your "mods", even though they don't really affect the engine's running or what caused the crack. This happened to me, in that I have Fuel Pressure, EGT, and Boost gauges, as well as an upgraded transmission with a double-deep pan on it, and an Emjay transmission shift controller.
If you have a modded engine, depending on your mods, and how difficult they are to remove with no evidence left, you may have a fight on your hands. Remove everything you can, and be prepared to challenge everything they gripe about on it. The gauges do NOT have anything to do with the engine block cracking, and they know it. The dealer may try to tell you they have never seen a block crack. It's a bold faced LIE! Unless the dealer just opened it's doors or they don't have Dodge trucks in that area, someone there knows all about it, and the Dodge regional rep who must inspect the engine to approve warranty service on the block, due to its cost, knows all about it.
This frustrated me, as my dealer told me they never heard of such a thing happening to these engine blocks. While I never actually got a chance to speak to the regional rep, the dealer told me the rep said he had never seen an engine block crack. Another lie. The rep only wanted to pick my truck apart, and said the crack was cause by "over torque". More BS.
I will relate my experience and what I have heard, to get warranty service when Dodge tries to wiggle out from under it. I heard someone else say that they called Cummins to yell about it, and Cummins got Dodge to take care of it. This is actually what I ended up doing also. In my case, I took my truck to the Cummins dealer in my area, Mid-Atlantic Cummins, and a service writer there helped my with the warranty matters. My plan was to have my "aftermarket" warranty I purchased with the truck pay for the repair since Dodge rejected it. It turns out their "fine print" says they won't pay for any block problems that aren't "caused by an internally lubricated part". That's when I called Cummins about my problem and they got in touch with someone higher up at Dodge to take care of my warranty issue. Cummins number is 800-DIESELS.
New Information
I have now confirmed 2 rumors as fact. The first being that "53" blocks were in trucks with a year model as late as 2001, and the second, that a "53" can appear on the right side of the block also, or instead. The following pictures were sent to me by the owner of a 2001 Ram with a "53" block in it.
More new Info
This link is to a discussion where it is said that there are 2 different version of the "53" block, and one or more prone to cracking than the other. The judgment of which block you have starts getting subjective since you have to look for casting problems to decide. See thread: 53 blocked 12 valve
Old Jan 10, 2014 | 03:12 AM
97cummins's Avatar
Old Jan 10, 2014 | 07:15 AM
Razdad's Avatar
Thanks but I already knew about the 53 block before I bought the truck.The thing was it has over 200K on it and has never had a issue and the truck has only been used to haul a trailer with horses and was in very good condition so I bought it&you would think if it(the Block)was going to crack it would've done so by now.I know my cousin has 1 that has 650 HP and he has never had a problem.So I don't know but I do appreciate any and all feedback.
Old Jan 13, 2014 | 12:13 AM
BBD Tech Support's Avatar
cutthroatxxx
Mar 19, 2015 09:26 PM
Jan 22, 2015 02:40 PM
metal_miner
Diesel Engine Conversions
Dec 23, 2014 11:40 PM
Slim Whitey
Nov 8, 2014 09:41 PM
Oct 8, 2014 11:50 AM
