engine knock
Old Jan 7, 2014 | 02:10 PM
53swampy's Avatar
Default engine knock
My 6.5 has a knock that goes away when i crack the fuel line on #2 cylinder. The engine is a new Jasper,new pump,new PMD located front of rad,new turbo boost sensor,new coolant temp sensor, new injectors. #2cyl I have changed the injector twice, bad injector no! Some blue-grey smoke not alot. Plenty of power, knock nearly goes away when driving.Starts good, idles near good but not perfect. What wrong?
Old Jan 7, 2014 | 02:14 PM
dallonj's Avatar
Sounds like a bad piston or bearing you might want to get a comprrssion test done and or go back to where you got the motor from
Old Jan 7, 2014 | 06:28 PM
Mase's Avatar
How many miles on new injectors,some times it takes a little bit for them to seat and get quit.If jasper put them in and not you they are most likely not new.
Old Jan 10, 2014 | 10:51 AM
racer55's Avatar
I re read the thread and ask you to ignore my post-I can't delete it for some reason.
Old Mar 6, 2014 | 05:27 AM
Drot drot's Avatar
Hi mate me to got a 6.5 that has in intermittent knock ,sound like its at the back left cylinder.
Old Mar 6, 2014 | 08:23 AM
racer55's Avatar
Knocks are often from bad injectors.
burndiesel
10
Feb 7, 2023 01:15 AM
klein444
Jun 20, 2015 11:48 PM
hershwork
Mar 1, 2015 05:15 PM
metal_miner
Diesel Engine Conversions
Dec 23, 2014 11:40 PM
Oct 30, 2014 08:10 AM
