Someone please help or ill post a burning dodge video
Old Jan 6, 2014 | 09:27 AM
elimackinnon's Avatar
Default Someone please help or ill post a burning dodge video
ok, so I have a 2001 Dodge 2500 6 speed, I have been having "dead peddle" issues for quite some time now and it is really getting annoying. I have replaced the vp44,apps,map sensor,fuel filter,fuel lines, lift pump and I am still getting the dreaded dead peddle. when im driving down the road it will be fine for a few miles then I loose power and only have about 1/4 peddle, if i turn off the ignition and back on I get full peddle again and full power.
Old Jan 6, 2014 | 07:40 PM
RAW's Avatar
RAW
Any codes?
Any modifications to the truck?
Old Jan 6, 2014 | 07:48 PM
There is a edge juice with attitude, intake, straight pipe, up graded lift pump. The codes are p1693 p0216 p0123. I think the p1693 is a old code
Old Jan 6, 2014 | 08:12 PM
jigabop's Avatar
1693 is companion code IIRC... (too lazy to search right now )
sounds like you got a bad vp44.
APPS dead pedal won't give you a 1/4 pedal...it will just be dead till you push on and off 3 times and then it will come back till it gets a bad reading again and it goes dead again to prevent runaway from a false reading.
apps will never limit to 1/4 pedal and just keep working...that is without a doubt a vp44 electronic issue.
If you replaced it recently, I hope you didn't wire tap it and F yourself out of the warranty...
always a good idea to run a new vp44 untapped for a couple months to be sure it is a good pump before you tap it.
BTW I totally wanna see the burning dodge video!
Old Jan 6, 2014 | 08:31 PM
That's what I was thinking too was the vp44 I bought it from advance metal products in Utah az so it's not like I can just get a new one over night, they want me to send this one back and them check it out then either send me a new one or send this one back. So this is going to leave me truckled for god knows how long
Old Jan 8, 2014 | 08:43 PM
pimba24's Avatar
I'd have to agree the VP is shot. P0216 is known as "the code of death" for VP44's it really is a timing failure code. Hopefully they don't screw you around for too long. But heres a list of most of the bad VP Codes.
P0216
P1688
P1689
P0215
P0370
P0251 - P0260
Dec 29, 2014 10:20 AM
Dec 12, 2014 12:30 PM
Nov 16, 2014 06:10 PM
Nov 3, 2014 08:10 AM
Oct 10, 2014 08:10 AM
