48re Reverse Shudder @ Take off
Old Jan 5, 2014 | 09:59 PM
Tony8473's Avatar
Default 48re Reverse Shudder @ Take off
Please watch the video any input would really help. I have a 2006 Dodge 3500 4x4 DRW Edge Juice w/ Attitude, AFE Stage ll, 5" 1 Piece Drive Line, ATS Stage 2 Trans w/ Triple Lok TC. When backing empty or loaded this happens. I have put into 4wd and same, removed drive line and used 4wd ( front drive only ) and still the same. I have had 4 TC replacements and 3 Trans replacements. It is far worse as you see in video with trailer / load but does do it empty. Other than this the trans operates awesome. Any help would be helpful, again does it with rear drive line removed....makes no difference. Truck has 48k miles ( orig miles ) Thanks in advance.
Video link of my truck backing:
Old Jan 6, 2014 | 09:23 AM
illinoisfox's Avatar
Drop the pan and check the rear band adjustment. It might be loose.
Old Jan 6, 2014 | 11:28 AM
Tony8473's Avatar
I did that and that was unsuccessful we also tried installing a super servo and that was also unsuccessful I am at a complete loss but thank you for your input I truly appreciate it
Old Jan 8, 2014 | 10:11 AM
dangerous1965's Avatar
Increase line pressure or just get a goerend constant pressure valve body! Hopefully the friction discs are still good.
Old Jan 9, 2014 | 12:36 AM
Tony8473's Avatar
Thanks for the reply. The builder is giving me another trans and doing mods to it to fit my needs better ( owning an RV dealership and always backing and towing ). I will keep you posted on what they did and how it works.
Old Jan 9, 2014 | 09:35 PM
I had the same problem I'm a transporter of 5th wheel trailers. After putting in the Goerend valve body no more shutter! Been 100k no problems! Need anything taken to CA let me know!
Old Jan 9, 2014 | 10:21 PM
Tony8473's Avatar
Up
I will for sure! Heading to Portland OR Saturday and was in LA for 2 others Tuesday. I may just need you!
alexcummins2341
Jul 31, 2015 11:21 PM
jeremiah1
Jul 21, 2015 06:35 PM
Jgloveracob
Wanted To Buy (WTB) - Used
Apr 18, 2015 04:19 AM
99&91cummins
Feb 28, 2015 09:28 AM
97PS
14
Feb 19, 2015 11:21 AM
