HX35 Turbo Or Compressor Upgrade
Old Apr 17, 2008 | 07:58 PM
Power Ram Man's Avatar
Default HX35 Turbo Or Compressor Upgrade
what would produce more power a rebuilt hx35 in my truck or get a compressor upgrade on the h1c like stage 3
Old Apr 17, 2008 | 10:03 PM
94cummins12v's Avatar
go with the HX35 with the HX40 hybrid upgarde
Old Apr 18, 2008 | 09:24 AM
Diesel Dummy's Avatar
Well first off a stage 3 on the H1c will make it a hybrid, that would be the best route a s there will be no machining involved, the gains will be the same as doing a hx35/40hybrid but its all bolt on and go with the H1c. You will see more gains with it than just putting on an HX-35. DD
Old Apr 19, 2008 | 09:41 PM
its a tough decision
Old Apr 19, 2008 | 10:52 PM
Actually its not, you wont gain squat with just an hx35 just more spool up and higher egt's. With the stage 3 you will gain more air to burn more fuel, try to find a 16cm housing and you will have a nice allaround turbo to handle what ever pump mods you do. DD
Old Jul 1, 2008 | 06:42 PM
K204DR's Avatar
can you just put a h1e compressor housing, wheel and backing plate on a h1c for a 60mm upgrade?
Old Jul 17, 2008 | 07:57 PM
already have a 16cm housing
Old Jul 17, 2008 | 08:18 PM
RSWORDS's Avatar
Yes you can. Have a BRAND new H1E wainting at the house for me to get th eballs to make the hybrid.
Old Sep 7, 2008 | 08:28 PM
07Chassis's Avatar
Just got an h1e compressor off what I believe to be an 8.3 (forgot to read engine code) with a rod through the block. Taking the compressor, wheel and backing plate was no problem at the junkyard. Save the t-bolt clamps your old ones might break. I paid 15.00 for half the turbo. Just remember the compressor nut is reverse thread..I feel bad I broke the one at the junkyard.
Anyway, swapped the h1e on my h1c stock exhaust housing and it pulls great up top now. Smoke cleared up fully at full throttle. Needs more fuel.
Old Sep 7, 2008 | 08:56 PM
More fuel........ thats the easy part!!!!!!!!!!!
