Won't start when hot and ruins real rough
Old Jan 5, 2014 | 09:01 AM
huntingmachine's Avatar
Default Won't start when hot and ruins real rough
So I went through some water the other day and ever done my truck won't start when it hot and ruins really rough and blows a few puffs of white smoke into its warmed up then it runs fine with just a little turbo lag I've replace the stem tubes and dummy plugs and the ficm is reading 48v any guesses what could be the problem.
Old Jan 10, 2014 | 11:55 AM
sickopstrokefan's Avatar
just a wild ges... And i cud b wrong. But my truck did same thing. I noticed my glowplug module was soaked plus I had problems with it earlier. Any CEL on? Most likely system voletage short. To injectors. Where, is anyone's ges. I'm gonna ges wire grounding out. Otherwise I cant help ya! Sorry. Hope ya figure it out.
Old Jan 18, 2014 | 08:12 PM
I checked and didn't see nothing wrong but my fuel mileage has gone in the toilet I'm at 4-6 mpg I'm about to take it to Ford and let them deal with it
Old Jan 18, 2014 | 09:59 PM
bobfbigman's Avatar
A hot no start is normally a High Pressure oil leak, I see you replaced the standpipes and dummy plugs but did you replace the STC fitting on the High Pressure Oil Pump? it is more common for that to fail then the other parts you replaced.
Old Jan 24, 2014 | 09:55 PM
detroitdiesel idi's Avatar
Hpop oil rail o rings are bad you tube powerstrokehelp channel and you will find a detail video
