What is the problem
Old Jan 5, 2014 | 02:35 PM
PowertotheStroke's Avatar
Default What is the problem
Bought the 06 F250 about 5 months ago with 108k miles. Dealer said that the reason it was traded in was because of needing an EGR Cooler or Valve and an FIMC and that he had them replaced. The truck now has a k&n intake, mbrp 4in tbe, and a livewire with innovative extreme street tune that I've been running. Changed the Oil, and Fuel Filters around 110k miles and this problem started a couple hundred miles after the custom tune.
The truck has been blowing white smoke at idle and when I pull out from a stop but then the smoke stops once I get rolling. At WOT it seems to be misfiring and jerking. Not sure if that's correct terminology as this is my first diesel. But the oil temp usually stays around 6-13 degrees higher than the coolant temp so I thought about narrowing out the oil cooler. The degas doesn't seem to be "puking" coolant but there is just a little excess but nothing I thought was to much. The truck still has bolts but other than this what was done with the previous owner exceeds my knowledge.
I think I've narrowed it down to the egr cooler because I pulled off the egr valve and saw condensation in the intake
Last edited by PowertotheStroke; Jan 5, 2014 at 02:35 PM. Reason: Automerged Doublepost
Old Jan 10, 2014 | 11:58 AM
sickopstrokefan's Avatar
Just fyi, with that tune ur stock bolts probably wont last long. mine ddnt!
Old Jan 12, 2014 | 03:11 AM
lpnsteve's Avatar
Yeah you might want to think about deleting the EGR and getting studs if you're are going to be running those tunes.
burndiesel
10
Feb 7, 2023 01:15 AM
Jake9473
Jul 22, 2018 08:19 AM
jeremy01995
Sep 14, 2015 06:34 PM
thurobred1320
May 5, 2015 09:26 PM
Dadslb7
Dec 9, 2014 11:05 PM
