INtroduction
Old Jan 4, 2014 | 10:33 PM
Bofinger's Avatar
Default INtroduction
I am a refrigeration efficiency expert, and am interested in re-use of various oils for fuel. Own a 2002 Ford F350 with a 7.3 liter engine. Have purchased a 300 rpm centrifugal filter for about $1000 and have filtered a few small batches. Burned 5 gallons of new gear oil in 15 gallons of pump diesel, and it worked fine. Been establishing contacts with local shops to get waste tranny oil and crankcase oil. I have noted that there is some smoking that is embarrassing, and want to get that under control. Just made a batch today, about 12 gallons in my almost empty tank, lot of red gear oils in it. The truck smoked after a few miles, so I bought 19 gallons of pump diesel. It significantly reduced smoke, but she still does smoke a bit. I would like not to create a unpleasant environment for those behind me. Recently read a study on lube, and saw that adding a quart of biodiesel is one of the best things for lubrication. If bio were not such a hassle, I would be more inclined to make that. I am hoping to get the waste motor oil process figured out to make healthy use of WMO.
Old Jan 5, 2014 | 08:08 PM
97cummins's Avatar
Old Jan 5, 2014 | 10:56 PM
Bofinger's Avatar
I was unable to see anything in your post, except the signature graphic. Can you send again, or e-mail me at Bofinger.r@gmail.com I am not having that great of success navigating this site.
Old Jan 8, 2014 | 04:10 AM
97cummins's Avatar
First go to the section you need to post in.
Look at the upper lt. corner of the page and you’ll see a button that says new thread, click on that.
Type in the title above the main section
Go down to the main page and type your question
then below that, you’ll see the button that says post quick reply.
If it doesn’t work let me know.
Oleoleson
Apr 13, 2015 03:43 PM
Dudeman
Ironmanqb
Mar 18, 2015 11:26 AM
jpaltauf
Dec 10, 2014 12:35 PM
Newtruckforme
Oct 28, 2014 03:26 PM
