Torque Converter Cooler
Old Jan 4, 2014 | 01:35 PM
1realdivaintx's Avatar
Question Torque Converter Cooler
Please help. I'm searching for a torque converter cooler for a 2006 Dodge Ram 3500 5.9L automatic transmission. I cannot afford to purchase one from the dealership.
Old Jan 4, 2014 | 07:40 PM
dangerous1965's Avatar
Tranny cooler is mounted up by the radiator. There is a heater cooler on the engine drivers side. Which do you need? Check Ebay for either one go aftermarket on the cooler "Bigger"
Old Jan 4, 2014 | 08:33 PM
Bigg Redd's Avatar
Sorry to hijack, but is that heater cooler absolutely necessary? Will the truck operate normally with out it?
Old Jan 5, 2014 | 01:46 PM
cerberus60's Avatar
The TQ converter cooler is frequently referred to as the heat exchanger on the block. Yes, it can be deleted and a fan activated cooler added under the bed. It will take longer for the trans to warm up so a chyange in driving style may be needed.
Check with TC Diesel, I think he has a cheaper alternative than the dealer heat exchanger.
Old Jan 5, 2014 | 02:50 PM
Question This is picture of the part the I need
Torque Converter Cooler-2006-dodge.jpgClick image for larger version
Name:	2006 Dodge.jpg
Old Jan 8, 2014 | 10:17 AM
Yeah that goes in the block drivers side. But you can bypass it. There is a aftermarket thermostat available now set at 160 that you can put inline to keep the tranny at temp! Driving in cold weather is the only time that is needed and it gets the temps up faster. Running cold ATF is bad for the tranny!
Old Jan 8, 2014 | 10:32 PM
Bigg Redd's Avatar
I am very interested. Where do I get this item? Not towing, my trans temp is just barely above 140*. WHen I tow my 9800 lb travel trailer, its right at 170*, in the hot summer. Since its been so darned cold here in Texas my trans temp takes quite a bit of time to warm up.
Old Jan 9, 2014 | 09:31 PM
I'll look up the link when I get home! I'll post it tonight!
Here it is! High-Flow Transmission Fluid Thermostat, 160F
Last edited by dangerous1965; Jan 9, 2014 at 09:31 PM. Reason: Automerged Doublepost
Old Jan 9, 2014 | 10:55 PM
Bigg Redd's Avatar
Dude, youre the man!!! Many thanks!!!
Old Sep 1, 2014 | 08:42 PM
Megablue2006's Avatar
Ok just ordering If this is a complete replacement where it still hooks up to the coolant lines as well? If so what fittings should I order?
