Now I Got Some Codes?
Old Apr 17, 2008 | 06:51 PM
shilo's Avatar
Default Now I Got Some Codes?
Ok i did the key switch trick and got me some codes.
0500
1682
1693
So what do these mean? I read what they "mean" but in other words what are they? And how to fix em?
Old Apr 17, 2008 | 06:57 PM
Benjamin's Avatar
Bombardier
0500
1682
1693
P0500 Vehicle Speed Sensor Malfunction
p1682 Charging System Voltage Too Low
p1693 is a companion code
looks like you have an alternator charging problem or a battery that is going bad.... this can make alot of things seem bad to the comp. what is yer voltage at the batteries when the vehicle is not running and what is it when the engine is running/alternator charging?
Old Apr 17, 2008 | 07:02 PM
Ok, so what is the truck doing?
P0500 - usually nothing to worry about - generally means the rear wheels have been spinning. Been doing any burnouts?
P1682 - Charging System Voltage Low
P1693 - A Companion Code - likely related to the P1682
Is your alternator charging?
Old Apr 17, 2008 | 10:00 PM
shilo's Avatar
No burnouts. But on a trip to higher elevation the truck choked and blew blue smoke. I posted a thread about it on here too.
I replaced the alternator in november. And if i remember just from glancing at the dash regularly it runs around 14 voltsish. The truck sat for about an hour prior to taking these codes. Ill check battery voltage in the morning. And their 1.5 year old optima red tops.
However, recently i plugged in my tow lights for my jeep and after maybe a mile i smelled something smoking and my check gauges light turned on and the voltage dropped to zero. I unplugged the lights and the voltage stayed at zero. I drove to moab, shut the truck down for an hour and when restarting it worked fine. So i havent done anything else to it. Voltage seems good now.
Old Apr 17, 2008 | 10:04 PM
Uncle Bubba's Avatar
Sounds like a voltage regulator problem, that's an internal component in our trucks. I would also have those Optimas tested at a shop. Be sure they dissconnect them and test them individually. They have a habit of dropping cells.
Old Apr 17, 2008 | 10:07 PM
shilo's Avatar
Where is the voltage regulator? And how much is one gonna set me back?
Old Apr 17, 2008 | 10:11 PM
On our truck the regulator is internal inside the alternator. The alternator is rebuildable though you don't have to buy a new one unless it's really jacked up. The auto shop that checks your batteries should also be able to test this regulator for you and tell you if it's bad.
Old Apr 17, 2008 | 10:20 PM
shilo's Avatar
The alternator is from autozone and has 1 year warranty so im going to have em check it out.
Ok, here might be the cause: I drove to Industrial Injections shop and changed out my Silver Bullet for the Silver 62. I did the swap in their parking lot (awsome guys). While tightning a bolt, dont remember which, i touched the hot post on the back of the alternator with the wrench and it stuck to it for a moment before i could jerk it free. A few minutes after starting the truck the Check Gauges light came on and had zero volts. I went to autozone, tested the alternator and it failed. Still on warranty I changed out the alternator in their parking lot. After starting it i had the same problem. After a check of fuses i found that the 140 amp alternator fuse was blown. (shoulda checked fuses first). So in goes a new fuse and everythings great till now. So i think i shorted something else too.
(by the way the fuses look good now)
Old Apr 17, 2008 | 10:25 PM
Batteries or battery may have fried also then. I'm bein optomistic here cause I don't want to get into what could have happend until you check these things out.
Old Apr 17, 2008 | 10:29 PM
shilo's Avatar
Haha...oh im afraid of what could have went wrong. Ill have the batteries tested tomorrow. Thanks...im off to bed and ill let all know of the battery situmacation.
