HELP: Slow refueling caused check engine light
Old Jan 2, 2014 | 11:21 PM
Russ125's Avatar
Default HELP: Slow refueling caused check engine light
Ill start by saying I have a 1999 Cummins 5spd with 108,000 miles on it. No issues thus far.
However, tonight I went to refuel and the pump that I always go to was pumping oddly slow, it seemed weird to me so i stopped pumping. I put 9 gallons in my tank before stopping the pump and getting the rest of my money from the clerk. When I started my truck the check engine light went on (it never has before). I wanted to get my truck home because I only live about a mile from the station. While driving home I noticed my rpm gauge go from 1800 rpm's down to 0 quickly, it did this about 3-4 times then went back to normal.... the weird thing is my engine still remained at the same speed and sound when the gauge was at zero... so I didn't have any power loss the needle was just dancing.
Im not sure if the slow pump was due to the fact that it's 7 degrees here in Detroit Michigan or if the tank was almost empty.
note: I run an anti-gel/water separator supplement to my fuel every time I fill up and my "water in fuel" light did not come on. Also my fuel pressure remained at its normal 10-11 psi.
Any input would be greatly appreciated
Old Jan 4, 2014 | 12:20 PM
Russ125's Avatar
Well never mind turns out it had nothing to do with the fuel the code came back as P0336 -Crankshaft Position Sensor. I plan on replacing it once the part gets to my local Cummins dealer. It just seemed too strange that the CEL would come on right after I had issues with that particular pump.
burndiesel
10
Feb 7, 2023 01:15 AM
Higgy
Jun 5, 2015 09:16 AM
Gm3500
May 7, 2015 11:01 AM
gauge1325
May 3, 2015 01:33 PM
moneypitk5
Feb 12, 2015 11:01 AM
