Injection pump or lift pump?
Old Jan 2, 2014 | 11:22 AM
bcstroker744's Avatar
Default Injection pump or lift pump?
Truck starts idles and drives fine. Until at highway speeds it seems to have a slight fuel "cut" or miss. I have a receipt for raptor lift pump and reman vp44 from 10/2009. Truck is an 01 mostly stock. No fuel pressure gauge. Any help is appreciated.
Sent from my SPH-D710 using Tapatalk
Old Jan 3, 2014 | 01:14 PM
lukesdiesel's Avatar
Have you had it checked for codes?
Luke
Old Jan 3, 2014 | 02:08 PM
tbirdz24v's Avatar
My raptor pump has a pressure regulator on the pump. Try cranking up the pressure if it does. I had the same issue with my truck. Which is when I got the raptor. It fixed my issue.
Old Jan 3, 2014 | 02:10 PM
The only codes it throws are tranny codes from the swap. And ill check it later this afternoon
Old May 4, 2014 | 09:07 AM
Hotrodd_67's Avatar
If your trucks throwing codes how do I know what that mean.how do I find out .thanks guys
Old May 4, 2014 | 11:38 AM
Fuel Pressure?
Luke
Old May 4, 2014 | 09:53 PM
trigger_3001's Avatar
Usually just type it into google and you can find it
landon025
Sep 8, 2015 09:21 PM
RatsMC
May 4, 2015 05:25 PM
Renteria1217
Apr 16, 2015 11:38 PM
klein444
Feb 21, 2015 10:33 AM
moneypitk5
Feb 12, 2015 11:01 AM
