suspension and tires
Old Jan 2, 2014 | 09:33 AM
99stackedpowerstroke's Avatar
Default suspension and tires
So I ordered a leveling kit for my truck and now the front sits higher could I take blocks off a 1ton and fix it? Right now the front sits 1/2-3/4 of an inch higher. And also was wondering if I could run 305/75/16 on factory rims or would I need aftermarket rims or if those tires would even fit.
Old Jan 2, 2014 | 01:47 PM
HeavyAssault's Avatar
Check the rear OEM block height. The F350 block runs like 3.75" in height so you nay have some growth there.
Old Jan 6, 2014 | 09:15 AM
warpeddiesel's Avatar
That should work on the blocks. I think the f250 block is 2 inch. Switching them out may make the rear an inch higher. F350 blocks are 3 3/4 as stated above. If you want to get it closer a 3 inch block from 4wheel parts would work just fine, for about $40. As for the tires they should fit, but that being a wider tire you would prolly need to get a wheel with more backspacing to prevent from rubbing while turning
Old Jan 6, 2014 | 10:21 PM
Adrenaline junkie's Avatar
I have 325/65-18 with leveling kit on stock offset 9 in wide rims. . . Only rub is slight on leaf spring at full lock . . Put over 20000 miles on and heavy right foot. 305 should fit no problem!
Apr 30, 2015 08:10 AM
6.Revvin
Tire, Wheel & Suspension
Apr 30, 2015 05:09 AM
ChgoSquad5
Ford Powerstroke 2011-Up 6.7L
Jan 6, 2015 11:37 PM
BubbaDT55
Nov 18, 2014 06:24 PM
