luke warm heat
Old Jan 2, 2014 | 07:03 AM
TheMacster's Avatar
Default luke warm heat
My radiator crapped out on me Sunday, split the plastic side tank. I replaced it and filled it with new fresh coolant. Now my heat only blows luke warm. It worked fine before. Its about 15 to 20 degree out. What do you guys think?
Old Jan 2, 2014 | 07:48 PM
Pclem's Avatar
Thermostat stuck open, or possible bad heater core. have the system back flushed by like jiffy lube or most oil change places there could be a build up of crap blocking the flow
Old Jan 4, 2014 | 11:38 PM
ramrunner01's Avatar
i had this problem too id try back flushing your heater core its simple and im sure thats all it is does it get warmer when you give it gas?
Old Jan 5, 2014 | 02:01 PM
TheMacster's Avatar
I did the thermostat last night and I still don't have good heat. The gauge stays around the 190 mark. How do I back flush it? I thought about hooking a garden hose to it but everything is frozen. Could it be an air pocket and I have to open one of those plugs in the head?
Old Jan 5, 2014 | 02:23 PM
You could have an air pocket but to flush the heater core there is two hoses running into the firewall them and run your garden hose through the colder hose for about 5 minutes or so when I did it I let it heat up enough to where I could feel one of the hoses get warm and than I pulled the colder one and run the water in that way let me know if that helps at all
Old Jan 5, 2014 | 03:13 PM
dog's Avatar
dog
I had the same problem But I bought the purple radiator flush from XDP and It fixed her up. I now have hot air coming from the vents instead of ice cold air haha
Old Jan 5, 2014 | 04:24 PM
TheMacster's Avatar
Royal purple radiator additive?
Old Jan 8, 2014 | 06:58 PM
AFRenoughsaid's Avatar
Get ready to pull your dash you probably need a new heater core if flushing it wont work
Old Jan 8, 2014 | 07:20 PM
TheMacster's Avatar
I don't have any coolant smell, there isn't any in the cab, and I haven't had any smoke come from the vents. So I don't think it's the heater core. I'm waiting for the weather to break to try and flush it.
Old Jan 10, 2014 | 05:45 PM
Hotrodd_67's Avatar
How do I get rid of an air pocket in my 2002 dodge ram cummins
Some please help me
Last edited by Hotrodd_67; Jan 10, 2014 at 05:45 PM. Reason: Automerged Doublepost
