Think I screwed up????
Old Jan 1, 2014 | 11:08 AM
MudDrivermike's Avatar
Default Think I screwed up????
Just to get some feedback. On a previous topic of mine i had an isuue with what I thought was an IP issue. Either way I got everything close to being back to normal by turning up everything more than I had it before the issue. One thing I just realized I did, I messed with the overflow valve.. When I was trying to figure out the issue, I found some rubber in the screen in the overflow valve. It wasnt new from when I rebuilt it. It was something old prior to that. Anyway, I was trying to clean it out with a pick and ripped the littte screen inside. So my bright idea next was to remove the beat up screen. So I got a drill bit and took EVERYTHING out of the valve. So now its basically a banjo bolt..I didnt realize that the center was a metered oriface to keep a certain amount of fuel in the injection pump. My question is,,,,will this affect the performance of the pump. Even with everything cranked up,its not 100%. And Im wondering if this is a big deal. If this can cause an issue then Im going to replace it ASAP. Thanks In advance ..Mike
Dam...... Nobody?????
Last edited by MudDrivermike; Jan 1, 2014 at 11:08 AM. Reason: Automerged Doublepost
Old Jan 4, 2014 | 08:41 AM
bump
Old Jan 11, 2014 | 03:28 PM
I guess I just wasted my time.. Wish I could now delete this topic.
Old Jan 11, 2014 | 04:59 PM
12vcumminspower7's Avatar
It's going to affect the performance of the truck it letting way to much fuel return to the tank,but just buy a 40 hp Overflow Valve for $25 from Tork Tec,shipping is fast!
Old Jan 12, 2014 | 08:36 AM
Thanks for the reply. I wanted to know one way or another. And i figured with over 200 people that looked at the topic, that at least somebody would have any kind of answer. As of now I have my power screw all the way in to get the same results of when I only had 2.5 turns in. I will get another overflow valve and see if this sets everything back the way it supposed to. I will eventually do that and update this thread of what the out come is ..Thanks again.
gunman41mag
The Sportsmen's Lounge
8
Mar 26, 2015 01:16 PM
